First post, by Barry_Purplelips
Is there a way to tell which resolution/refresh rate an application is using? taking a screenshot would help with the resolution part, but what about the refresh rate?
Normally I just run the application outside DosBox and check what my monitor switched to via it's built-in settings menu (hoping vga.sys isn't screwing things up) but certain applications plainly and simply won't run on bare XP no matter what.
Thanks in advance.
Reply 1 of 12, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
A debug-enabled build of DOSBox should give you this information.
1+1=10
Reply 2 of 12, by Barry_Purplelips
Thank you, that was fast! I'll see if I can get the debug thing running.
Reply 3 of 12, by Barry_Purplelips
Jesus Christ almighty, this is going to be more complicated than I foresaw.
Wouldn't it be great to have said information (plus color depth) available from the status window? can't help but make it a feature request.
Regards.
Reply 4 of 12, by wd
Rank DOSBox Author
DOSBox Author
Nope. Just clutters the status window with useless information.
Reply 5 of 12, by Barry_Purplelips
If it's useless, why does the debugger show it?
Reply 6 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
in the debugger it is not useless as the non average users uses that one.
You know that in the dev forum there is a precompiled debugger version available.
Water flows down the stream
Reply 7 of 12, by wd
Rank DOSBox Author
DOSBox Author
Because those people who use the debugger require it.
Reply 8 of 12, by Barry_Purplelips
So then it's useful. It's never a good thing to make such an assumption for everybody. Obviously some users don't care about being able to recreate a proper DOS experience, so they're perfectly ok with a piece of crap windowed, upscaled, de-syncing image, but that's them, not me, I favor using the original resolutions and refresh rates in fullscreen, which can be a lil tricky as you must usually add custom modelines for acceptable precision.
Anyways, how could something like "8-bit 320x200@69.8xxxxxx" clutter the window in any way?
@Qbix: yes, though I haven't found the debug-enabled binaries for 0.74. Guess I'll have to give 0.73 a try.
Reply 9 of 12, by leileilol
Maybe a 'report current res/depth/rate to console' hotkey would work.
Reply 10 of 12, by DosFreak
Displaying Color, resolution and refresh rate info is useless for most users. Don't know why you can't see that.
They just want it to "work".
Overlay like what ScummVM does for scalers would likely be the best bet.
Make your games work offline
Reply 11 of 12, by Barry_Purplelips
He said it would clutter the status window and that has absolutely nothing to do with your assumption that most users wouldn't find this information useful.
Too much work just to please a handful or nerds? I can live with that, but alleging cluttering? not convincing enough.
Reply 12 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
get the debugger version which is precompiled and be happy.
Thread closed.
