SPD reprogrammer
First post, by swaaye
I've been frustrated over my freebie Dell 4600's RAM restrictions. It will only run PC3200 speed with CAS 3 RAM. If I mix CAS 2.5 with 3, it drops to PC2700. Stupidity.
So I was thinking of buying some new RAM but really didn't want to because I'm swimming in RAM already. Then I remembered that I'd read about SPD reprogramming. You can change what the DIMMs report they support.
Thaiphoon Burner. 😁
http://www.softnology.biz/
I reprogrammed 2x512 and 2x256 to 3-3-3-8 and now they all work at PC3200 in the quirky Dell. Makes me joyous.
Reply 1 of 3, by sliderider
swaaye wrote:
I've been frustrated over my freebie Dell 4600's RAM restrictions. It will only run PC3200 speed with CAS 3 RAM. If I mix CAS 2. […]
Thaiphoon Burner. 😁
Wait. Let me see if I got this right. you're reprogramming your RAM to run faster than the manufacturer intended without overclocking it?
Reply 2 of 3, by swaaye
Actually I'm setting the two 256MB DIMMs to run at less agressive timings than they came at. The Dell box only likes CAS 3 @ 200 MHz (PC3200).
Yes I could go the other way and reprogram them all for 2-2-2-5 or something. Whatever you want. I'm sure that wouldn't work very well with these DIMMs though.
This is really only useful for dumb OEM mobos that have no BIOS mem options. Notebooks come to mind too.
Reply 3 of 3, by MURLON
swaaye, thanks for the info! I have just purchased Thaiphoon Burner and flashed my PC100 stick with PC125 SPD. Works great so far! Nice tool!
