First post, by eri
I'm trying to run the King's Quest games from Gog. They worked great the very first time I ran them after installing, but right after shutting the game off and restarting, it won't work. DosBox is crashing before I even get to an opening screen. I tried installing the latest edition and opening that separately, but I get the error 'SDL: can't set palatte' and then it crashes.
I'm running this on Windows XP in Mac OSX Parallels (Intel machine). Like I said, it ran great the first time, just can't get it to start again. Any advice? Thanks.
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
use the mac version of DOSBox ?
Water flows down the stream
Reply 2 of 9, by eri
OK, it's working fine on the Mac. Possibly dumb question - how do I get the games from Parallels to the Mac so I can play them there instead? I can't seem to find a .exe file for the games, just an icon that plays them.
Reply 3 of 9, by eri
Wait, that's not my dumb question. I got the .exe file copied over, but when I try to run it under DosBox I get 'illegal command'. I know I mounted it to the correct directory. Can I not run a .exe file in DosBox running it from a Mac environment? Do I have to alter the file somehow?
Reply 4 of 9, by eri
Now I'm VERY confused. It's claiming that the program must be run under Win32. But if that's the case, why when I try to run it under Windows does it open DosBox, which then crashes? If it's not a dos program, why is it trying to run in dos? If it is a dos program, why can't I run it from dos?
Reply 5 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
you install the game in parrallels
copy the folder where it is installed to your mac
run dosbox for mac with those files
Reply 6 of 9, by eri
OK, if anyone cares (or if it might help anyone) I think I've solved it - I can run it without DosBox crashing in Parallels if I set the resolution to 64bpp. 8 crashes, 32 will do sound only, no images.
Reply 7 of 9, by eL_PuSHeR
[Moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 8 of 9, by IIGS_User
You may read the threads Play your Goold Old Games on a Mac and/or Q: GOG games on Mac? browsing the GOG forums,
or try to run older KQ games (1 - 3, AGI version of 4) in ScummVM (which would not need any installation).
Klimawandel.
