First post, by peasant
- Newbie
Recently I got an itch to pull out my old PCI Voodoo from the closet, blow the dust off and try out some Glide games on my XP 32-bit system. I removed the GTS 250 and installed the Voodoo, not bothering to set PCI video to boot first in the BIOS. Screen came on and Windows loaded normally, recognizes the card and starts the driver update wizard, but around this time it locks up.
Next I plug my monitor into onboard and reseat the Voodoo in another slot, hoping to just get it recognized and installed without locking up. This time the computer freezes before Windows gets to the login screen. Tried it a couple more times in different slots and with different PSU connectors with similar results; computer locks up either before or right after loading the desktop. Once I remove the card the lockups cease.
I did note the card was quite hot in the middle whenever I pulled it out but both fans seem to be working on it and nothing seems damaged or missing. I'm aware failure is common for cards this old so I'm not expecting miracles, however the card does still boot at least. I'll crosspost this to 3dfxzone and hope somebody has some good advice.
