Reply 20 of 54, by ratfink
Revised my results, you were right mau1wurf1977 now I get 71.4. 🤣
Seems to have been because the CPU to PCI buffer was disabled in the bios. No idea why, I got this machine as a whole so I never checked the jumpers or bios settings.
Reply 21 of 54, by Amigaz
Ok I've ran this stuff on my Compaq Deskpro 386/20E
CPU: Cyrix 386->486 upgrade cpu running at 40mhz (1k L1 cache)
Mainboard: Compaq's own stuff
Amount of RAM: 16mb
Amount of L2 Cache: 32k
Video card: Ati Mach32 DRAM 2mb ISA
3dbench score: 15,3
Will bench one of my Eisa 486 systems shortly which has speedy VLB gfx
My retro computer stuff: https://lychee.jjserver.net/#16136303902327
Reply 22 of 54, by Machine_1760
Another Benchmark for you:
PC 3
CPU: Intel 486 DX-50
Mainboard: Unknown (no stickers or manufacturer's markings anywhere)
Amount of RAM: 16 mb
Amount of L2 Cache: 256kb
Video card: Trident TVGA9000C (ISA)
3dbench score: 25.6
Reply 23 of 54, by Mau1wurf1977
Now we are talking 😀
Reply 24 of 54, by DBob
My "test" machine
CPU: Intel 486 DX4-100
Mainboard: Unknown (Compaq Prolinea 4100 board)
Amount of RAM: 40 MB
Amount of L2 Cache: 128 kB
Video card: Cirrus Logic GD5434-8 (integrated PCI)
3dbench score: 71.4
Here is a pic from sst as well.
Reply 26 of 54, by Mau1wurf1977
I also got a score!
It's not a 486, but a Intel Pentium 100. It's not that much faster than some of your 486 cpus...
The CPU runs on a Super Socket 7 board, loads of cache, super fast AGP video card so pretty much as good as it gets...
Tester: Me (Mau1wurf1977)
CPU: Intel Pentium 100 (66 x 1.5)
Mainboard: Aopen Aopen AX59 Pro (Super Socket 7 board)
Amount of RAM: 64mb
Amount of L2 Cache: 1024kb
Video card: AGP Geforce MX440
3dbench score: 90.9
My YouTube channel
Reply 28 of 54, by retro games 100
Mau1wurf1977 wrote:
Looking for more 386 results guys!
386SX (16, 20 and 25) and 386DX (25, 33 and 40) would be nice 😀
Yes, more 386 based scores would be really good to read. BTW, looking at my previous 486 testing, is the 486 SX-25 result any good to you?
SX-25 CPU (not SL enchanced, and no writeback)
Superscape 3Dbench 1.0 = 20.4
Reply 29 of 54, by Mau1wurf1977
Updated! Thanks
Based on that score, I put down the Cyrix with all Cache disabled as a 386DX-40 because it scores ~ 18 points...
Reply 30 of 54, by yuhong
Machine: PS/2 Model 30-386
I wonder what led that to be displayed.
Reply 31 of 54, by Amigaz
I'll drag up my mega pimped 386DX 33mhz 64k cache beast from the basement shortly 😀
Reply 32 of 54, by Mau1wurf1977
Excellent!
My table has a score of around 13 for a 386DX-33. Very interested to see what you will get!
Reply 33 of 54, by aitotat
3Dbench gave 15.8 fps for below system:
CPU: AMD 386DX-40 MHz
MOBO: MB-4D50L (OPTi 82C495 SX chipset), 256 kiB cache
RAM: 4 x 4 MiB 60 ns
Graphics card: #9GXE (S3 928) ISA
That motherboard is 386DX/486 hybrid motherboard and it has two VLB slots. I could try some VLB cards if you are interested how they perform on a 386.
Edit: I forgot to mention that the #9GXE has 1 MiB DRAM + 2 MiB VRAM. It has a wait state jumper and it is set to zero. Motherboard ISA divider is set to 5 so ISA clock rate is 8 MHz as it should. So nothing is over clocked.
Reply 34 of 54, by Mau1wurf1977
Awesome! Thanks!
Question for you...
Does you mainboard have a jumper for 33 or 25 MHz (instead of 40)?
Because if it does you could also provide us scores for a 386DX-25 and 33!
No need to test other videocards, yours is just fine...
Reply 35 of 54, by Amigaz
I'm currently out of town but tomorrow I'll provide you with results from two different 386DX 33mhz machines 😀
Reply 36 of 54, by keropi
no surprises there, my PS1/pro could just be a PS2 variant without the EISA/MCA slots. This machine uses 72pin ECC ram 😳 which is quite weird for a 386sx-only pc (cpu soldered onboard , no upgrade slots)
another weird IBM thing is that the 1.44MB floppy has no power connector, it gets it's power from the standard floppy calbe... 😮
Reply 37 of 54, by 386DX40
CPU: AMD 5x86 133MHz (L1 cache in WT mode due to BIOS limitations)
Motherboard: Chaintech 4SPI Sis496/497 ISA PCI
RAM: 128MB (all cacheable by L2)
L2 cache: 512kb WT mode due to BIOS limitations
Video card: S3 Virge PCI 4MB
3dbench score: 62.5
Reply 39 of 54, by aitotat
It does and 25 MHz is the slowest it supports. Here are results for 25, 33 and 40 MHz. I also tested with VLB card since I wanted to know is there any benefit from having VLB on a 386. There isn't. I got only a little better results with VLB card. The difference is so small that I cannot even be sure is it because of VLB or because of better graphics chip.
CPU: AMD 386DX-40 MHz (same CPU underclocked for 33 MHz and 25 MHz tests)
Mainboard: MB-4D50L (OPTi 82C495 SX chipset)
Amount of RAM: 16 MiB (4 x 4 MiB, 60 ns)
Amount of External Cache: 256 kiB, 15 ns
Video card (ISA tests): #9GXE (S3 928)
Video card (VLB tests): #9GXE64 (S3 864)
3Dbench v1.0 results
Clock | ISA | VLB
25 MHz : 9.8 FPS | 11.4 FPS
33 MHz : 13.1 FPS | 15.3 FPS
40 MHz : 15.8 FPS | 18.5 FPS
