First post, by Paddan1000
- Member
I have a Sound Blaster Pro 1, the old one you know, with the dual OPL2 and jumpers and all.
Both sound effects and OPL2 MIDI work, but the sound from my MT-32 is not forwarded when I connect its output to the "Line In" or "Mic In" of the Sb Pro. Why not?
(The MT-32 gets its MIDI signals from a Voyetra MIDI-interface and works perfectly with a separate speaker.)
I don't use any drivers or anything. I've only added a SET BLASTER line to autoexec.bat. Do I need some driver or mixing software to activate the "Line In"?
