First post, by juniorjj 84
Well im having a hard time with this dosbox thing, im trying to install and run some of my oldies and i cant, i try to install ACES OF THE DEEP, from cd on no luck, when i finally install it, theres no sound, i hat to copy the entire cd on my hard drive, got it to run, but no sound at all, it keep telling me that it cant find the soundset file, and while installing it keep telling me that some files are missing.
ANY HELP WILL BE MOST WELCOME.
OR I WILL GO NUTS.
Reply 1 of 20, by SKARDAVNELNATE
Elaborate on what you mean by "no luck". Did you successfully mount the CD? Does the install end in an error?
Does the game have a setup program to set up the sound?
Might the sound settings be contained in a .bat file as opposed to runing the .exe file?
Reply 3 of 20, by juniorjj 84
I THINK IM DOING EVERYTHING WRONG, SO LETS START FROM THE TOP>>>>>
MY SYSTEM::::
WINDOWS 7 x64
HARD DRIVE IS PARTITION::
C:\ MAIN DRIVE,,,,WINDOWS, PROGRAMS, BOOT DRIVE,,,ETC
D:\ DRIVE,,,,GAMES, PATCHES,,,ETC
E:\ DRIVE,,,,CD ROM
JOYSTICK,,,,,LOGITECH DUAL ACTION GAME PAD, USB
OK: the dosbox is install in c:\ drive, and no problem there
My real problem is that i need to be taken step by step on how to mount the drivers correctly on my comp, since i try the instructions and no luck there, like how to mount my D:\ drive and the E:\drive, when i try to mound my E:\ drive cdrom it keep telling me that the drive doesnt exist,
so im confused there, then i cant install since my games are from the cd rom, and if i get to install them how to use my hard drive and th cd rom at the same time, usually i use DRIVE D:\ FOR MY GAMES,i also notice that at one time i was able to get to the install part and when it ask me to choose a drive to install, there were no drive or anything to install to, i mean it was blank, so no install posible.
i did manage to install SYSTEM SHOCK, PLEASE DONT ASK ME HOW, I DID IT BY MISTAKE ,CAUSE I DONT REMEMBER HOW I DID IT BUT THE JOYSTICK WASNT PRESENT, NO JOYSTICK AT ALL. THE GAME RAN FINE.
SO, if anybody can guide me step by step i will apreciatted very much. HELPPPPPPP
Reply 4 of 20, by HunterZ
I have moved this thread to DOSBox General.
juniorjj: Please read the relevant DOSBox guides in the DOSBox Guides section of the forum - they may be of help: DOSBox Guides
Edit: In particular, the "60 seconds" guide has info on mounting CD-ROMs etc.
Reply 5 of 20, by SKARDAVNELNATE
So you want to use D:\ to store games and your CD-ROM is E:\
Create some folder on D:\ that will be used in DOSBox.
MOUNT C D:\some_folder
MOUNT D E:\ -t cdrom
Reply 6 of 20, by HunterZ
Also, make sure you have a disc in the CD-ROM drive before you try to mount it.
Reply 7 of 20, by juniorjj 84
OK, GUYS THANK YOU FOR THE HELP, I FINALLY GOT IT TO WORK, EXCELLENT, AND THANK YOU ALL FOR YOUR HELP AND SUPPORT.
NOW ONE MORE THING:::
I have a LOGITECH GAME PAD(usb) install as a joystick, and some how it doesnt work, i try to calibreted in the game or games and it doesnt work, at one time i manage to get it to work, but the plane(strike commander game) was all over the place, do to the joystick not been able to calibrate propertly. any ideas on why this is happenning?
ANSWERS ARE VERY WELCOME""""
AND ONCE AGAIN:: THANK YOU ALL, GAMES ARE RUNNING GREAT.
Reply 8 of 20, by HunterZ
First, make sure the joystick is working correctly in Windows (look for the Game Controllers tool in the Control Panel). There should be a way to get a test screen with axis and button status. If you can calibrate there, do it.
Second, make sure you're calibrating it properly in your DOSBox game.
Finally, you may need to change the timed= setting in your DOSBox options. I had to set timed=false to get my Logitech gamepad working well with X-Wing.
Reply 9 of 20, by juniorjj 84
My joystick is working fine in windows, i even play games in SNS EMULATOR, and works fine, i did calibrated withing the games i try but no luck, but i didnt know about the timer thing you mention, so im going to try that and see if it wioks, but its odd cause i try crusader and the joystick works, but i couldnt use the buttons, and i mean it works is that i was able to move left, right, up, down without any eratic move, so lets try that timer thing and see what happens, THANKS FOR THE SCOOP. I LET YOU KNOW IF IT WORKS.
Reply 10 of 20, by HunterZ
Hmm you didn't mention before that the axes worked but not the buttons. That is strange. Maybe post here what your current DOSBox joystick settings are.
Reply 11 of 20, by juniorjj 84
I dont know if this is what you ask to post but this is what i get from dosbox when i open it, i dont know how to configure the joystick in dos box, so maybe thats the problem, but i configure it within the game and didnt work, it keeps moving all over the place erratically, so what should i do?
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\Users\Luis H Chaparro\AppDat
a\Local\DOSBox\dosbox-0.74.conf
MIDI:Opened device:win32
One joystick reported, initializing with 4axis
Using joystick Logitech Dual Action USB with 4 axes, 12 buttons and 1 hat(s)
Reply 12 of 20, by HunterZ
Go to the Start Menu in Windows and navigate to All Programs -> DOSBox and then launch DOSBox Options. That's where you configure DOSBox unless you're using a frontend utility.
Reply 13 of 20, by juniorjj 84
Ok, i got it, now how or where i configure my joystick buttons, my joystick has 12 buttons that can be use, so question? in order to config each button do i have the choice to simulate each command that each game have, i mean for example::: if im flying an aircraft and i press :c: on my keyboard and i drop chaff, then if i simulate that key on the joystick, will i will be droping chaff? Follow me? but most importantly where an how i config my joystick? first i have to get the sucker to work, it still moves all over the place.
Reply 14 of 20, by HunterZ
Re-read my earlier post:
I'm not sure if DOSBox lets you map joystick buttons to keys. You might try reading the DOSBox readme and playing with the keyboard mapper.
DOSBox *can* also emulate more advance DOS joysticks with extra buttons (such as CH flightsticks) if your DOS game supports those.
Reply 15 of 20, by juniorjj 84
I will try later on with the setting you recomend, i havent try it yet, and i think i saw somewhere that i can remap the joystick keys in the maper section, but only if i can figure out where to do it, see i havent have much time to play with dosbox, thats why i ask lots of questions, i will get this weekend off and dedicate my self to it, but i have gather some knowleged from you so i wont be as lost, THANKS FOR THE TIME AND PATTION, i really apreciated. By the way my gamepad has to sticks, left, right, plus the buttons, WHICH JOYSTICK YOU RECOMMEND I SHOLUD USE IN THE CONFIG BOX?
:::One joystick reported, initializing with 4axis
Reply 16 of 20, by HunterZ
What are the options?
I have that same gamepad, by the way.
Reply 17 of 20, by juniorjj 84
Here are some options that i found::::::
[joystick]
# joysticktype: Type of joystick to emulate: auto (default), none,
# 2axis (supports two joysticks),
# 4axis (supports one joystick, first joystick used),
# 4axis_2 (supports one joystick, second joystick used),
# fcs (Thrustmaster), ch (CH Flightstick).
# none disables joystick emulation.
# auto chooses emulation depending on real joystick(s).
# (Remember to reset dosbox's mapperfile if you saved it earlier)
# Possible values: auto, 2axis, 4axis, 4axis_2, fcs, ch, none.
# timed: enable timed intervals for axis. Experiment with this option, if your joystick drifts (away).
# autofire: continuously fires as long as you keep the button pressed.
# swap34: swap the 3rd and the 4th axis. can be useful for certain joysticks.
# buttonwrap: enable button wrapping at the number of emulated buttons.
joysticktype=auto
timed=false
autofire=false
swap34=false
buttonwrap=false
SO WHICH ONE SHOULD I USE OR YOU RECOMMEND?
Reply 18 of 20, by juniorjj 84
BY THE WAY, DO YOU KNOW HOW TO USE THE MAPER FILE? i look at it the other day but look complicated to me, maybe i need to familiarize with this dosbox thing, and I FINALY GOT THE JOYSTICK TO WORK, I USE YOUR RECOMANDATION ON USING THE "FALSE" IN THE CONFIG, AND WORKS GREAT, THANKS FOR THE SCOOP. IF NOW TO THE MAPPING THING.
Reply 19 of 20, by HunterZ
I can't recommend which one to use because I've never played Aces of the Deep. Maybe try ch, fcs, then 4axis and decide which works best for you.
I also can't help much with the mapping stuff, as I haven't messed with it much myself because it seemed complicated to me too.
Glad you got your joystick working.
