First post, by Malik
The following are the supported chipsets of UNIVBE 6.7 :
UNIVBE67 readme.txt wrote:
. 3DLabs Permedia, Permedia 2, Permedia 2V . Acer Labs M3141/5, M3147V . AHEAD V5000A, V5000B . Alliance ProMotion 3210, ProMoti […]
. Alliance ProMotion 3210, ProMotion 6410, ProMotion 6422, ProMotion AT24
. Alliance ProMotion AT25, ProMotion AT3D
. ARK Logic ARK1000VL, ARK1000PV, ARK2000PV, ARK2000MT, Quadro64
. ATI 18800, 28800, Mach32 68800, Mach64 88800GX, Mach64 88800CX, Mach64 CT
. ATI Mach64 ET, Mach64 VT, Mach64 VT4, Mach64 VTB, 3D Rage, 3D Rage II
. ATI 3D Rage II+, 3D Rage IIC, 3D Rage Pro, 3D Rage LT Pro, Rage Mobility
. ATI Rage XL
. Avance Logic ALG2101, ALG2201, ALG2228, ALG2301, ALG2302, ALG2032, ALG2064
. Avance Logic ALG2564, ALG25128
. BrookTree BtV 2115
. Chips & Tech C&T C&T 82c450, 82c451, C&T 82c452, C&T 82c453, C&T 82c455
. Chips & Tech C&T 82c456, C&T 82c457, C&T 65510 LCD, C&T 65520 LCD
. Chips & Tech C&T 65530 LCD, C&T 65535 LCD, C&T 65540 LCD, C&T 65545 LCD
. Chips & Tech C&T 65546 LCD, C&T 65548 LCD, C&T 64300 WinGine
. Chips & Tech C&T 64310 WinGine, C&T 65550 LCD, C&T 65554 LCD, C&T 65555 LCD
. Chromatic Research Mpact!
. Cirrus Logic CL-GD5401 (AVGA1), CL-GD5402 (AVGA2), CL-GD5420, CL-GD5422
. Cirrus Logic CL-GD5424, CL-GD5426, CL-GD5428, CL-GD5429, CL-GD5430
. Cirrus Logic CL-GD5434, CL-GD5436, CL-GD5440, CL-GD5446, CL-GD5462
. Cirrus Logic CL-GD5464, CL-GD5465
, CL-GD6205 LCD, CL-GD6215 LCD
. Cirrus Logic CL-GD6225 LCD, CL-GD6235 LCD, CL-GD6245 LCD, CL-GD6410
. Cirrus Logic CL-GD6412, CL-GD6420, CL-GD6440, CL-GD7541 LCD, CL-GD7542 LCD
. Cirrus Logic CL-GD7543 LCD, CL-GD7548 LCD
. Compaq IVGS, AVGA, QVision 1024, QVision 1280
. Diamond Viper P9000+W5186, P9000+Oak87
. Everex Trident, ET4000
. Genoa GVGA
. Hualon HM86304, HM86314
. IIT AGX-010/11, AGX-014, AGX-015, AGX-016, AGX-017
. InteGraphics IGA1680, IGA1682, IGA1683, CyberPro2000, CyberPro2010
. Intel i740
. iXMICRO TwinTurbo 128, TwinTurbo 128+, TwinTurbo 128-3D
. Macronix MXIC 86000, MXIC 86010, MXIC 86100, MXIC 86101, MXIC 86200
. Macronix MXIC 86250, MXIC 86251
. Matrox MGA Ultima, MGA Impression Plus, MGA Millennium, MGA Millennium II
. Matrox MGA Mystique, MGA Mystique 220, Productiva G100, Millenium G200
. NCR 77C21, 77C22, 77C22E, 77C22E+, 77C32BLT
. NeoMagic NM2070, NM2090, NM2093, NM2097, NM2160, NM2200
. Number Nine Imagine 128, Imagine 128 II, Ticket 2 Ride
. NVIDIA STG2000, NV1, RIVA-128, RIVA-TNT, RIVA-TNT2
. OAK OTI-037C, OTI-057, OTI-067, OTI-077, OTI-087, Eon 64017
. OAK Spitfire 64105, Spitfire 64107, Spitfire 64111, Eon 64217, Warp 5
. Paradise/Phillips Pipeline 9710, Pipeline 9712
. Paradise/Western Digital PVGA1A, WD90C00/PVGA1B, WD90C10, WD90C11, WD90C20
. Paradise/Western Digital WD90C20A, WD90C22, WD90C24, WD90C26A, WD90C30
. Paradise/Western Digital WD90C31, WD90C33
. Primus P2000
. RealTek RTG3103, RTG3105, RTG3106
. Rendition Verite V1000, Verite V2100/V2200
. S3 86c801, 86c805, 86c911, 86c924, 86c928, Vision 864, Vision 964
. S3 Vision 868, Vision 968, Trio32, Trio64, Trio64V+, Trio64UV+
. S3 Trio64V2/DX, Aurora64V+, Trio3D, Savage3D, Virge, Virge/DX/GX
. S3 Virge/VX, Virge/GX2
. Sierra Falcon/64, SuperScaler 220
. Silicon Motion Lynx SM910
. SiS 6201, 6202, 6205, 6215, 6326, 5597/5598, 5595/530, 5595/620
. S-MOS SPC8106
. Trident LX8200, TVGA8800CS, TVGA8900, TVGA9000, TVGA9100, TVGA9200
. Trident Cyber9320 LCD, Cyber9382 LCD, Cyber9385 LCD, Cyber9397 LCD
. Trident TGUI9400, TGUI9420, TGUI9440, TVG9470, TGUI9660, TGUI9680
. Trident ProVidia9682, ProVidia9685, 3DImage 975, 3DImage 985
. Tritech Pyramid3D
. Tseng Labs ET3000, ET4000, ET4000/W32, ET6000, ET6100, ET6300
. UMC UM85c408, UM85c418
. Video7 VEGA, HT208, HT209, HT216
. Weitek P9000, P9100
. WinBond W9970CF
(The names in bold are those I know that are available.)
I can see from http://www.gaby.de/win3x/edrivers.htm, the drivers for Windows 3.1x.
Does anyone know of any other drivers for the above video cards available for Windows 3.x?
And does anyone have the said drivers?
I'm trying to collect the drivers for these.
Also, I'll be grateful if anyone can share experiences regarding the above chipsets, with regards to their performances and compatibility with Dos games and also, the clarity of fonts and colour intensity in Windows 3.1x?
Thanks for any help!
Reply 1 of 5, by Markk
Do you need to run windows 3.0 ? I ask that beause if you say 3.1x I suppose it includes both 3.1(3.10) and 3.11. By the way, on my 286 I have windows 3, and a trident 8900 card, and I thought I should try to install win 3.1 drivers I already had, but I just couldn't. There was not an option "have disk" in the video card list. So I guess for win 3 the drivers should have an installation program, too.
Reply 2 of 5, by GL1zdA
Have you tried Metropoli? Also in some shareware collections archives like textfiles (I don't remember the other site) you can find old drivers.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 3 of 5, by GL1zdA
You can't use 3.1 drivers for 3.0, they're different. Have you tried: infos and drivers
Reply 4 of 5, by Malik
@Markk : No, only for the Windows 3.1 and 3.11. Thanks.
@GL1zdA : I remember visiting Metropoli often previously, but forgotten about it for sometime now. Thanks for reminding.
Reply 5 of 5, by Markk
GL1zdA wow thanks! Great collection of drivers! I didn't have too many hopes with win 3.1 drivers, but I thought I should give it a try just in case..
EDIT : Thanks to that link, I finally found win 3 drivers for that old trident card. As it described in the readme, you have to choose driver from disk using the dos-based setup of windows. So it's ok, I can have vga resolution with 256 colors, or 800x600 with 16colors, but in the end I switched back to vga 16 colors.. It was a significant difference in speed when using higher resolution or more colors. And anyway, I'm not going to really use this version on windows on this machine. I just wanted to have as many versions running in various pcs, just for historical reasons. 😀
