First post, by steve_40
I've noticed an annoying glitch in DOSBox 0.74 and several earlier versions. After running DOSBox and then exiting, all the processes on my PC have their affinity changed from 4 cores to only 2 cores, which degrades the PC's performance. I have to reboot the PC to restore things back to normal. You can check for yourself using the Windows task manager, then right-click on a running process (such as explorer.exe) and choosing "Set Affinity..." only CPU 0 and CPU 1 will be enabled.
Anyone else noticed this? It would be nice if DOSBox could reactivate the other two cores when it has finished doing its job!
