First post, by tronds
- Newbie
I'll go straight to the problem.
When I try to execute this batch file, Dosbox freezes (No error message) and the only thing to do is to use Task Manager and force-quit it.
This is the bat file I'm trying to execute:
ECHO OFFCLS:MENUECHO.ECHO ...............................................ECHO PRESS 1 or 2 to select your task, or 3 to EXIT.ECHO ...............................................ECHO.ECHO 1 - Export Favorites from COMPUTER to PERSONAL DRIVE (P:)ECHO 2 - Import Favorites from PERSONAL DRIVE (P:) to COMPUTERECHO 3 - EXITECHO.SET /P M=Type 1, 2, or 3, then press ENTER:IF %M%==1 GOTO EXPORTIF %M%==2 GOTO IMPORTIF %M%==3 GOTO EOF:EXPORTXCOPY "%userprofile%"\Favorites\*.* P:\Favorites\ /S/YGOTO MENU:IMPORTXCOPY P:\Favorites "%userprofile%"\Favorites\*.* /SGOTO MENU
Whenever I try to launch another bat-file it works fine, so I guess it's a problem with this specific bat-file. Could someone confirm this?
Thank you in advance.
