I need input.
First post, by dosquest
Okay, I recently formatted my hd and I'm wondering what os to put on it. I have available to install superdos dos 6.0 dos 6.2 and windows 2.0. what is the best choice?
Reply 1 of 12, by leileilol
Definitely not Windows 2.
Reply 3 of 12, by dosquest
Is dos 6.0 worse than dos 6.2? I mean dosbox is basically 5.0 and it is compatible with alot of games.
Reply 4 of 12, by Mau1wurf1977
Not aware of the differences but I doubt it would matter.
Personally I use Dos 6.22 (you can get download free update from Microsoft) and all my Retro games work fine.
I don't think DOSBox uses MS Dos 5.0...
My YouTube channel
Reply 5 of 12, by dosquest
Okay, so I can upgrade from 6.0 to 6.2?
Reply 7 of 12, by dosquest
Well, I won't have to worry about that because I found dos 6.2 install disks lying around 😁
Reply 8 of 12, by DonutKing
This page details the differences between DOS 6.0 and 6.2
http://www.zisman.ca/Articles/1993/DOS62.html
Basically some minor but noticable changes. Enough to reccomend 6.2 over 6.0
The difference between 6.2, 6.21 and 6.22 is that DoubleSpace is removed in 6.21 and 6.22 includes DriveSpace as its replacement. If this is a gaming machine I wouldn't bother with disk compression as some games have issues with it, and it increases your chances of data loss if your system crashes or loses power.
Reply 9 of 12, by dosquest
This will be a gaming machine. My specs are here My retro setup.
The sound card is incorrect I upgraded to an sb16 but hte rest of the specs are correct.
Reply 10 of 12, by Tetrium
Actually, I wouldn't bother with disk compression nowdays at all
Reply 11 of 12, by dosquest
Well, I'm back to square one again, my hd just crapped out again... >:O
Reply 12 of 12, by dosquest
Okay, quick update: I got a new hd and I installed win98se. Click This link to see the followup.
