First post, by dada
- Member
Hi there,
I was wondering if you could give me some advice. A while back I decided that I wanted to back up some of my old 5.25" floppies from way back when. Since I wasn't sure if it was possible to build in a 5.25" floppy reader in one of my newer computers I opted to search for a cheap second hand computer that had both 5.25" and 3.5" floppy drives so I could move them around to my newer computer.
I managed to find one of those computers for dirt cheap. It came without a monitor, but that wouldn't be a problem since I still had two (confirmed working) monochrome monitors.
So here's what happens when I hook up my old green CGA monitor:
Edit: I'm being told my domain name expired so the image might not be visible. I'm trying to get it back online.
So here's a picture of the video card itself: http://www.yjfy.com/images/oldhard/video/auto_mode_hega.jpg
It has a set of 5 dipswitches on the back but no combination seems to be able to make it work. I tried searching for the card on stason.org but I can't seem to find a card that matches it perfectly (most seem to refer to at least two sets of switches but mine only has one).
So, do you think I could get this to work? Or am I better off buying a card off of eBay that would? Do you have any suggestions for such a card?
Thanks! 😀
