Reply 20 of 29, by rick12373
- Oldbie
wrote:rick12373, I just read another one of your recent Voodoo related posts, and you said:
"When I got home I checked out my Pentium II 300 MHz. It has a Matrox Millennium II in it. The system is working so well that I decided to use this system for a Voodoo 1. Will that Matrox work with it? Or should I switch it for something else?"
Am I correct in assuming that you are trying to get a V1 card working in a system that once had a V2 in it? If this correct, then I feel more strongly now that you have driver issues. If I were you, and I mean that literally, then I would do a clean install of Win9x, on any old test HDD, and just see if you can get the V1 to work. Just to check out whether this thing works or not.
I have never had a Voodoo 2 if that is what you mean. The matrox is just a normal 2D card isn't it?
Not sure about the .inf file but the monitor and matrox work perfectly at all resolutions and at the correct refresh rate even now with the 3DFX in. It's just when a 3DFX game is run or if I try to use the test option in the 3DFX screen properties that the monitor freaks out. The 3DFX properties also will not let me set the glide refresh rate to anything other than 60. The monitor can run 60Hz though because if I choose 60Hz from the Matrox properties it works. Not that I want to run 60Hz of course.
This machine has Windows 98 but I boot just in to DOS and only run 98 if I need it. Can I reinstall 98 without changing the DOS installation? I have my DOS menus and games just the way I want them and don't want to change them.
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
