Reply 40 of 140, by dosquest
Um, I didn't get diagnose.exe with my install.
Reply 42 of 140, by dosquest
Um, also when I install the drivers I still don't have sound in dos mode. Though, I am using the shareware version of doom. I might unpack my cd collection and dig out my original full disc version of doom.
Reply 43 of 140, by leileilol
Doom came on a disc?
I know some shareware versions were disced (Gold Medallion v1.666 being the most notable one) but the original full Doom only had floppy releases. Ultimate Doom had a disc release, a preloading id online ordering release, another disc release, another disc release, and a Steam release.
Reply 44 of 140, by dosquest
Um, I have a doom one on disc.
Reply 45 of 140, by TheMAN
shareware or full thing.. doesn't matter... they both use the same engine
did the sound card get initialized by the drivers? did you run diagnose?
Reply 46 of 140, by dosquest
Okay, I will run diag also does it matter where the game is? I mean I have sound in windows 9X but when I run a dos game I have no sound, but does the game have to be in a specific file? I have it in c:\games
Reply 47 of 140, by leileilol
don't forget to run setup.exe
Reply 48 of 140, by TheMAN
exactly.... doom has its own config util for the sound... setup.exe is it... go in there and reselect all the sound devices... it will ask you the ports, irq, and dma when you do so (it will not display them otherwise)
Reply 49 of 140, by dosquest
I ran the doom setpu and I am able to get sfx to work but no background sound yet.
Okay, I ran the sb program and I got these settings: Base I/0:240H Mpu401:330h Irq:10 Dma:3,5 For some weird reason I get sfx in doom but I have yet to get the music to work. The cd-rom disk does not work in ms-dos mode because I haven't configured mscdex and put the proper lines in the autoexec and config.sys files but the cd-rom works in 9X so I need to fix that, as I remember the sound files were loaded from the cd-rom and if the cd-rom drive fails to lead in ms-dos mode then maybye that's why I have no sound.
Reply 50 of 140, by TheMAN
no
doom has ALL of the sounds loaded off of the WAD file... in fact, it shouldn't even depend on the CD at all!
run the doom setup.exe again, and make sure your music (midi) settings are set correctly
it's also weird how your card is running at DMA 3/5 for the wave portion... if it works, then who cares, but just remember DMA 3 is normally for the ECP parallel port
Reply 51 of 140, by dosquest
I selected dma 3 and it said it was in use by another peripheral so I chose dma 5.
Reply 52 of 140, by TheMAN
DMA 5 is for 16bit audio, you need to use DMA1
Reply 53 of 140, by Mau1wurf1977
So how did you install the drivers in the end?
IMO it's good practice to keep Windows drivers and DOS drivers separate.
Under real DOS all you need to do is run CTCM and then AWEUTIL /S.
The card will display what resources it's using.
If your DOS driver installation is botched up, remove all references in the batch files and start from scratch.
I don't know if the DOS/W3.1 installer is meant to be run under W98 DOS MODE.
The default config is A220, IRQ 5, DMAL 1, DMAH 5, MIDI 330
My YouTube channel
Reply 54 of 140, by TheMAN
with a PnP card, it can do something stupid like run on IRQ 10
and there are quite a few games that don't know anything about IRQ 10... this PnP madness in DOS is why I hate them in a retro box
Reply 55 of 140, by Mau1wurf1977
I never had this happen to me.
There a few things that can help though: In BIOS disable any unused resources such as printer and serial ports, floppy port if you don't use it, USB if you don't use it.
There is also a PnP option (Auto/Manual) and Reset somethingsomething (seems to reallocate resources).
If your card still uses odd resources, just use CTCU and manually change them. It gives you full control to what address, IRQ and DMA you want to use. CTCU will tell you if there is a clash. E.g. when I set my AWE64 to IRQ7, it mentioned a conflict. Turned out I forgot to disable the printer port 😜
It even allows you to disable features not used, such as: game port, AWE synth, or even disable everything BUT the gameport 😁
Under windows, the resources don't matter. The driver and layered structure of windows takes care of all of that.
Reply 56 of 140, by dosquest
Where do I get ctu? Also just a reminder, what are the dead default sb16 settings?
Reply 57 of 140, by Mau1wurf1977
CTCU is in the same folder as CTCM.
Default configuration is the same as posted a few posts above!
Reply 58 of 140, by dosquest
I don't have ctm or ctu! Also, sorry, I didn't see the last line the the above post.
Reply 59 of 140, by leileilol
CTU disbanded when Bauer stopped work- i mean ctcm/ctcu comes with the Creative driver package for the SB16/AWE cards. It's a TSR.
