udam_u wrote:^^ This is really good result for this card! Average results oscillate around 2600 points. If you encountered problem during usi […]
Currently using a Geforce 6800GS AGP 512mb in it but so far I get about 40-50% worse FPS in 3dmark06 compared to what I get with this card in an i875 Pentium 4 3.4 Extreme rig
My 3dmark06 score with the GF6800GS is 2802
^^ This is really good result for this card! Average results oscillate around 2600 points. If you encountered problem during using another application I recommend to use older drivers. The latest drivers are not the best for "antique" hardware. (; In this table you have mentioned which drivers are recommended for each graphics card:
http://www.3dnews.ru/download/drivers/video/nvidia_video
EDIT:
Are you sure you tested your graphics card using 3DM06 in the past? Maybe you tested it in 3DM05. They look very similar...
Your absolutely right, I had been running 3dm05 on my P4 extreme rig.
Here's some results:
C2D E6600, Asrock 4core dualsata2 Gainward 6800GT Golden Sample 256mb:
C2D E6600, Asrock 4core dualsata2 Gainward 6800GT Golden Sample 256mb flashed with Ultra BIOS:
Pentium 4 Extreme 3.4ghz, Abit IC7-G Gainward 6800GS 512mb:
Pentium 4 Extreme 3.4ghz, Abit IC7-G Radeon HD3850 512mb:
As expected the 3850 owns!! going to test it on the C2D E6600 rig to see if the Abit S478 rig is a bottleneck 😀
