First post, by rick12373
I recently had a thread where I was trying to see if my Voodoo 1 card was working. I had it installed in my P2 system and it seemed to be behaving strangely. So I decided to put it in my 486 DX4 100 machine. This won't get the best out of the card but for testing purposes it might show me if the card is faulty or not.
I need some suggestions for a DOS game that uses the Voodoo 1 so I can test the card in this machine.
Thanks.
486 DX4-100 (overdrive)
16MB 72-pin SIMM RAM (2x8MB)
1MB Diamond Speedstar Pro VLB video card
SB 16 Value CT2770
AOpen VI15G Socket 3 Motherboard
HDD/FDD VLB controller card
Reply 1 of 15, by bushwack
Descent II was the first game DOS game I played with my Voodoo. Tomb raider is excellent under DOS with a Voodoo card as well as Carmageddon.
Those require specific 3Dfx patches, or are you looking for native Voodoo games or demos?
Reply 2 of 15, by rick12373
I have Tomb Raider on there but I didn't see any options for Voodoo. Is there a patch? I thought it was Tomb Raider 2 that had Voodoo support. Is 2 for Windows only? I don't have Windows on the 486 though.
SB 16 Value CT2770
Reply 3 of 15, by batracio
Try the first Tomb Raider with a 3dfx patch (there is a hardware-dependent patch for Voodoo Graphics only, and a hardware-independent Voodoo Rush patch that works with any 3dfx hardware, dgVoodoo and Glidos emulators, and DosBox too). Moreover, it's one of the few Glide games that will work fine on a 486 machine.
EDIT: those patches are on Tomb Raider Unfinished Business 2nd CD-ROM. I have uploaded both files.
Reply 4 of 15, by elfuego
Shadow warrior worked under Voodoo also... and carmageddon 1.
Reply 5 of 15, by leileilol
Scorched Planet. It's one of the earliest ones, dating Sept 1996. A 3dfx demo is available.
Reply 7 of 15, by rick12373
Thanks for the help. I think I will try Tomb Raider first.
SB 16 Value CT2770
Reply 8 of 15, by leileilol
Tetrium wrote:
Interstate 76 was Voodoo 1 iirc
But only for the Gold edition. Plain vanilla i76 is software only
Reply 9 of 15, by RogueTrip2012
Is GLQuake too obvious? Wait GLQuake is windows right?
What is your voodoo 1 card doing anyways?
Also some older games need the drivers glide2x.ovl and glide2x.dll are copied to the games directory.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>Win XP . AMD 960T . 8GB . Q.K2200. SB X-Fi . 512GB SSD . 2TB HDD
> Win XI . i7 12700k . 96GB . RTX4070TI . 512GB NVME
Reply 10 of 15, by bushwack
Will not work in DOS as far as I know, uses Windows 95 OpenGL libraries.
Reply 11 of 15, by Yushatak
I recommend MDK. It works on a 486, but is too slow. If you get a glide copy it should run playably on a (high-end) 486 with a Voodoo.
Might be able to get GLQuake working using the HX extender, but I don't know if you could call the Voodoo card through it or if it would fallback on OpenGL emulation..
Reply 12 of 15, by Tetrium
I got the cd, I was confusing i76 with Nitro Riders, which on the cd states supports 3dfx hardware 😉
Off topic, but nevertheless interesting:It also mentions hardware support for Rendition and Power VR 😀
Reply 13 of 15, by Iris030380
Yeah if possible, VooDoo games always worked better in DOS. Everything was faster in Dos to be fair.
Tomb Raider, Carmageddon, Screamer 2 ... all seemed to be 5-10fps quicker than running in Win95. And it always felt sort of rad playing a voodoo game in DOS. It just felt like raw power.
Bring back DOS!
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 14 of 15, by leileilol
Not for me. The whole 'faster in DOS' seemed like a placebo effect. Then again I did have 64mb RAM at the time..... 😳 🤣
Reply 15 of 15, by elfuego
Nope. It was indeed so. Another fine example is the original Need For Speed. Under dos it was flying, under windows 95 it didnt exactly crawl, but it was a pain to run.
