First post, by jpbouza
No way I can make it work on my computer, it just says segmentation fault.
I tried it with dosbox 073 and 074 with no luck. I even compiled dosbox myself and it didn't work.
So, I decided to test it on a Linux 32 bits in virtualbox... and it works just fine.
Does anyone have any hints on this?
Thanks!
Reply 1 of 4, by eL_PuSHeR
Is DOSBox your main target?
Reply 2 of 4, by jpbouza
el_Pusher, what do you mean by "target"?
You mean if dosbox is the program I want to use and not other programs?
Reply 3 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Sounds like the problem that dosbox had on 64bit os x, the 64bit dynrec core crashes ;(
Either use current svn or compile 0.74 in 32bit.
As 32bit dosbox is MUCH faster, I'd recommend that.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 4, by eL_PuSHeR
Yes, I mean if you are planning on using mainly DOSBox.
