First post, by franpa
Has there been any progress towards allowing button combinations involving the Alt key? like Alt F1, Alt F2 etc.
They don't seem to do anything in The Settlers 2: Gold Edition (When the winter cheat is active). You use these combinations to adjust the speed of the game once the cheat mode is active, otherwise your limited to only normal and 2x speed 😒
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
alt combination should work fine.
Water flows down the stream
Reply 2 of 4, by franpa
True, have to disable the Usescancodes option/
my website
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
hmm that is odd. Do the F-keys work properly normally in dosbox ?
(be sure to have the F-Lock key setup correctly)
Reply 4 of 4, by franpa
Uhm, I meant in the DOSBox config file I had to disable the "usescancodes" setting, after that the Alt-F# key combinations worked fine.
my website
