First post, by retro games 100
- l33t
I put four 1MB 30-pin SIMMS in to a device called a SimmVerter, and plugged this in to one 72-pin SIMM slot on a mobo, and it worked. I then removed the four 1MB SIMMs, and then put in four 16MB SIMMs. Unfortunately, the mobo didn't POST.
I checked the mobo manual (Asus PVI-486SP3), and it allows 64MB in one of its SIMM banks, so as far as the mobo is concerned, there is no MB limit problem with 64MB. I wonder if there's an upper limit on the MB useage of the SimmVerter? Perhaps one or more of the 16MB SIMMs are damaged - what I'll do is test them on an AWE32. I was hoping to avoid this, because it's difficult to load up this card with the 16MB SIMMs, as they are fractionally too wide for the SIMM slots, and make installing them difficult.
