Reply 80 of 147, by retro games 100
- l33t
I've got the mobo stable @ 150 FSB using the 1.4 GHz tually, in Window 98. I'm using an nVidia GF3, and VIA's 4-in-1 chipset driver version 4.43. 3DMark 2001 works OK. I tried 155 FSB, but when the BIOS POST screen is about to display the line of text saying something like "Starting Windows", it doesn't show this line of text, but just hangs.
I wonder if it needs more IO volts? If true, then it's a pity that you can't increase IO voltage on this mobo.
