ATI Radeon 9800 Pro, quick test.
First post, by retro games 100
Introduction
I am testing an ATI Radeon 9800 Pro 128 MB AGP video card. Its part number is PN 109-A07500-00. It seems to have heatsinks on nearly every chip! I'm testing it on a KT133A based mobo with 256MB of RAM, and a mobile barton 2000+ rated CPU.
1) Link to this card's BIOS.
2) Link to the ATI video card flash utility, FlashRom version 2.4.
3) Links to the ATI Catalyst driver version 3.7. See note 3 below.
4) Link to the ATI Catalyst driver version 6.2.
Notes
1) The webpage for the BIOS says that the same BIOS can be found in the Crucial 9800 Pro, GeCube 9800 Pro, and Powercolor 9800 Pro cards. I assume this is the latest BIOS.
2) This utility works in DOS. BTW, I found out all of the card's relevant BIOS info by running Everest Ultimate.
3) Please google for this file. It's called wme-catalyst-7-93-030812a1-010735c-efg.exe. I tested some of these old ATI drivers, and information about these tests can be found below. I found that version 3.7 was the fastest.
4) This is the latest and final driver which works on W98. It was written with ME in mind, and is based on the WDM (windows driver model). It seems to be the slowest driver to use, when I tested it with Windows 98.
Benchmark info
I decided to test some of the old ATI Catalyst drivers. I wanted to see if they made the card run any faster or slower. I began with version 3.1, and ended with version 6.2. Uninstalling one version then installing another version was problematic. In the end, I got this technique working OK. What you need to do is this:
1) Uninstall the ATI Catalyst software found inside the Windows 98 Control Panel "add/remove" software area. If it's listed as one item such as "ATI Driver", then you just need to uninstall that, but if it's listed as a "cluster" of 3 apps, with one of them being called "uninstaller", then double-click on that one in order to uninstall all 3 of these apps. Then reboot.
2) Delete the "error / yellow exclamation mark!" VGA driver found inside the W98 control panel System / Display area. Then reboot.
3) When the desktop reappears, W98 will reinstall the VGA driver. Rebooting is not necessary at this point.
4) Run Driver Cleaner version 2.7. Select to clean out the "ATI" driver. Then reboot, although this may not be necessary.
5) Install the next ATI Catalyst driver for testing...
Benchmark data
The format below is x=y where x is the ATI Catalyst version and y is the score from 3DMark 2001 s.e.
3.1 = I could not get this to install. I don't think this version covers the Radeon 9800 Pro card. I think the Pro card was released after version 3.1 was released.
3.2 = I could not get this to install. The installation routine reported "infsetup errors". I expect this version does not cover the Pro card.
3.3 = I decided not to look for this version on the net.
3.4 = 11502
3.5 = 11506
3.6 = 11534
3.7 = 11663 (Fastest)
3.8 = 11554
3.9 = 11454
3.10 = 11528
3.? = I'm not sure if there are any more 3.x drivers, after version 3.10. I've seen 3.11 mentioned, but when I downloaded it, it was version 4.1
4.1 = 11489
4.2 = 11451
4.3 = 11297
4.4 = I don't think there's a driver for W98 from this version onwards. Apart from one more they did, which is version 6.2
6.2 = 10187 (Slowest)
It was a lot of "fun" trying to track down all of these old ATI w98 driver versions. If you want to do the same, here is a good tip. You'll find the Windows 2000/XP versions much easier to find. For example, just take a look on the oldapps.com website. Once you find them, notice that each download package has a text file in them with the large driver name. Copy this in to your clipboard, and paste it in to google, and then rename it to wme-xxxx, where xxxx is the large driver version number. (You want to remove the wxp-w2k letters.)
Then google for this search string. You'll then find the wme (windows me) driver versions fairly easily. Another tip is - change the first group of letters from wme-xxxx to control-panel-xxxx, if you find that the downloaded wme driver package has been "cut down" to just include the driver itself, and it does not contain the ATI control panel app. You can then track down the correct version number for the ATI control panel.
The card
Reply 1 of 35, by Iris030380
They really were not that pretty. But few cards were back then. But theyre lacklustre appearance hides the awesome power these cards hold.
I still need to buy a 9700pro and 9800pro for my collection, but they still fetch way too much money on ebay. And it seems people are holding on to them for a little too long.
I had a 9800pro a long time ago and there was an option on the control panel to switch openGL into ASCI(or was it ANSI?). Quake 3 looked amazing but it was a little hard to aim. Such a cool feature though!
Nice ramsinks BTW! 😈
I5-2500K @ 4.0Ghz + R9 290 + 8GB DDR3 1333 :: I3-540 @ 4.2 GHZ + 6870 4GB DDR3 2000 :: E6300 @ 2.7 GHZ + 1950XTX 2GB DDR2 800 :: A64 3700 + 1950PRO AGP 2GB DDR400 :: K63+ @ 550MHZ + V2 SLI 256 PC133:: P200 + MYSTIQUE / 3Dfx 128 PC66
Reply 2 of 35, by sliderider
These cards were awesome when they were first released in the form of the 9500/9700. I still have a 9500 here that was unlockable to a full 9700, the only difference being they put slower memory chips on the 9500 so you'll never get full 9700 speeds on those but you can come pretty close with the core. You have to steer clear of the 9500 Pro cards, though. They are the ones that have the memory chips arranged in a straight line across the top instead of in an L configuration like on the 9700. They used a core that is closer to the 9600 and has no unlockable pipes. The 9600 was an odd card in itself. It was actually slower in most cases than the 9500 it replaced. They were going for power efficiency and passive cooling with the 9600. I guess they figured putting a fan on was too big an expense for their entry level card so they knocked down the clocks to keep the chips from heating up too much. The 9800 was still outstanding even against the FX5800 from nVidia. It wouldn't be until the GF 6800 was released that nVidia would have a serious challenger for ATi to compete against. A 9700/9800 is probably the best card you could buy for games of that time frame. These cards are also the last ones that you can get that have an official Win 98 driver. NVidia hung on a bit longer with Win 98 so if you need the absolute fastest card for Win 98, then the GF 6x00 cards are what you want but the Radeons still aren't bad.
Reply 3 of 35, by Pippy P. Poopypants
Actually the 9500 (non-Pro) was the one that was missing half the rendering pipes (disabled by default). Whether you could unlock the disabled ones or not was all a matter of chance. The Pro still retained the 8 full pipes that the 9700/9800 has.
Reply 4 of 35, by luckybob
if you want a 9800pro. there is one on ebay that is being sold by an idiot that will probably go for cheap. aftermarket cooler too!
http://cgi.ebay.com/Video-Card-PN-109-a07500- … =item2a100828ee
Reply 5 of 35, by Pippy P. Poopypants
^ Haha, what a waste to give up, smh.
GUIs and reviews of other random stuff
Вфхуи ZoPиЕ m
СФИР Et. SEPOHЖ
Chebzon фt Ymeztoix © 1959 zem
Reply 6 of 35, by elfuego
But they halved the memory throughput , so the 9500 pro is still slower then 9700 (or the unlocked 9500!). Sliderider is right, if anything - the 9500 was the biggest bang for the buck of that time.
Reply 7 of 35, by swaaye
9500 Pro was but not the plain 9500. The plain 9500 was about the speed of a Ti 4400 or even 4200.
I think the plain 9700 was one of the more exciting options. They would often overclock right past the stock 9700 Pro. I had one that went from 275 to 360 MHz or something which put it in the realm of the 9800 Pro. That was a gigantic improvement over my previous Radeon 8500.
Reply 8 of 35, by Iris030380
I will never buy a card with an aftermarket cooler. It has to be 100% pureblood vanilla untampered. Just a weird tick I have, don't know why. But yes, clearly he don't know what he has, which also tells me theres a 50/50 chance it even works. And he is in America... 😖
I will sit and wait and watch... sooner or later one will come up that gives me a funny feeling inside my tummy.
Reply 9 of 35, by sprcorreia
Same feeling here. And if it comes boxed, with manuals and software it's just great! It's like you owned it from day one.
Reply 10 of 35, by Tetrium
I actually like many of the aftermarket coolers. I prefer a modded graphics card over having a jet engine inside my case...but that's just me. What I don't like is a modded card that has the aftermarket cooler epoxied to the GPU 🙁
And often the original fans are dead/very loud anyway, I'd rather not use them like this, but that's just my opinion though 😉
I do like original manuals and such, even though they may be totally outdated 😁
My retro rigs (old topic)
Report spammers here!
Reply 11 of 35, by sprcorreia
I do have cards with aftermarket coolers (mostly Zalman and Cooler Master), but i like to do it myself and keep the original cooler.
Reply 12 of 35, by luckybob
If you want an "original cooler" they are all over the place on ebay for like $5. Seriously. Becides, the cooler that he has on that card is a VERY GOOD cooler for its day. I had one on my 9600SE.
Reply 13 of 35, by elfuego
...only if you don't unlock it (why would you get a 9500 if not to unlock it?). Unlock success rate from the cards I've seen was nearly 100% and the 9500 as such had max 5% lower scores then original 9700 that you love so much 😀
In that way, its not even better then a Ti4400, but better then the GF FX 5800.
P.S. Unlocking is not overclocking - its a safe operation that requires only Rivatuner or similar program that will modify the driver a bit.
Reply 14 of 35, by sliderider
He's right. The 9500 non-pro with 128mb memory had the same 256-bit memory bus as the 9700/9700 Pro only with slower rated chips. The 9500 Pro came with a 128-bit memory bus, so unlocking a 9500 non-Pro to 8-pipes would make it faster than a 9500 Pro and almost as fast a vanilla 9700 with only the memory clocks holding it back. The 9700 Pro would still be the fastest. The 9500 non-Pro was also available with 64mb RAM and a 128-bit bus, so you really want to keep clear of that one.
Reply 15 of 35, by swaaye
Hmm well if you can unlock it and it works (I doubt they all do) then yeah it is pretty neat. But most of the 9500s used that board with the single row of RAM and were permanently 128-bit. I see a lot of those on fleabay. They came in both 64MB and 128MB configs.
My feeling is that the earliest 9500s were obviously just BIOS gimped 9700s. But later they did some cost reduction and made the simpler PCB.
Reply 16 of 35, by elfuego
Yup, though I havent heard much about the 64mb version and I certainly never seen one. But I've seen many of these:
http://www.pcgameshardware.com/screenshots/or … -scan-front.jpg
...and those were awesome 😀
The 'cheaper' version came with the 9600 / 9600 pro. Good cards, but not as good as the 'original' 9500 😉
P.S. I've searched the fleabay and I only got the 'real' versions of it:
http://cgi.ebay.de/Radeon-9500-128Mb-/2207735 … =item336720dc42
http://cgi.ebay.de/ATI-Radeon-9500-128-MB-/15 … =item2310336fa0
Reply 17 of 35, by swaaye
German Fleabay anyway. Yankee Fleabay has 2 128-bit boards and 1 256-bit right now. I'm surprised there are only 3. Of course there are a zillion 9700s yet because of all the old OEM sales.
I find the recently-built 9800s curious indeed. Surples R350 chips huh?
http://cgi.ebay.com/NEW-ATI-Radeon-9800-Pro-2 … =item41578bb521
Check out that cheap PCB 🤣 128-bit 9800 Pro huh?
Reply 18 of 35, by sliderider
That one pictured is a 9500 Pro. The non-Pro has two chips across the top and two down the back like a 9700 except for the 64mb version which has two across the top and two empty pads down the back for the two missing memory chips.
Originally the 9500 non-Pro was created so ATi could make use of their binned 9700 chips with defective pipes. When demand exceeded the supply of binned chips, they started using fully functional 9700 cores with 4 cores locked, so some do unlock and some artifact to varying degrees when you try to unlock them depending on how badly damaged the core is. I do not think this was ever the case with the Pro version of the card as they were never unlockable but they used a crippled memory controller to keep it from competing too directly with the 9700. ATi went through the same thing with the 9800 SE being unlockable to a full 9800 and the X800GTO2 being unlockable to a X850 XT. I think they started laser cutting their cores after that.
Reply 19 of 35, by swaaye
I have a X800GTO2 turned X850XT still. 😀 The RAM on mine is nuts and goes up to around 630MHz without issue.
I did not know of the magical intricacies of the lowly early 9500 NP. Actually I probably forgot 🤣
