First post, by filipetolhuizen
I know there's already a topic regarding this but it's old and unanswered. I'm still experiencing the same problem of the game working once in a while. No matter which renderer I choose I always get the same result. If I start a game and the car and track are not spinning in the following screen I get dwwin.exe a crash when the race is about to start. This is completely random. When I had a Geforce 6800 it always worked fine, but when I upgraded to a 8800GTX the problem started. Same thing with my current GTX260 core 216. The game is fully patched (firstly with the big patch, then with the 1.1 one). Is there any way that this could be fixed? The original system was a Core 2 Quad Q6600 with 2GB RAM, now it's a Q9650 with 3GB RAM. OS has always been Windows XP 32 bits.
Reply 1 of 3, by btw3d
You have to set your CPU frequency below 2.2GHz. You can do this in BIOS.
Reply 2 of 3, by filipetolhuizen
Is it CPU related? Why did it work with an older card on the same system? And also on a P4 3.4GHz with the same card.
Reply 3 of 3, by btw3d
I never heard of GPU influence. Setting CPU frequency to 2.1 or 2.0 GHz is the only solution for me.
