First post, by gamera99
- Newbie
Hello I am using a Japanese PC with 64Bit Windows 7, DOSBox 0.73, and I am trying to run the old game MicroProse F117 2.0. I have DOSBox set up on my PC and have had good luck running other old games like M1TP1 for example.
The problem is that the plus + key is needed for throttle in the F117 game. Unfortunately the + key is in a completely different position so it doesn't map right. The plus key on the numerical keypad also will not function as a plus key within the game.
(As an associated but non DOSBox problem, the tilde key is needed in the Flanker 2.0/LOMAC games, but the tilde key is in a completely different position and doesn't work for those games either).
Can anyone advise me what to do with this? I was thinking maybe there is a keyboard layout file for japanese PCs for DOSBox. Or maybe I could custom make one. Has anyone experienced this problem and can anyone offer advice? Thank you for your help.
