I think I need some different 1200uF capacitors than what I have for my Shuttle AV61V40 because they're about triple the width of the original capacitors on the motherboard.  Most of the capacitors I found were considerably bigger than the ones originally on the motherboard, so some had to be mounted at an angle in order for them to fit.  But I just can't fit 8 of the 9 1200uF capacitors I need to replace.  One was next to the slot, which was fairly simple to replace(although the capacitor is sitting at an angle off the motherboard), but the 8 other capacitors are spaced very close together behind the Slot 1 connector, making it near-impossible to fit the huge capacitors I got.
But I think I'll ditch that motherboard as the Soyo SY-6BA+ I got works, although something just doesn't make sense with this motherboard.  I tried 3 AGP graphics cards on the motherboard and while the computer POSTs(and I can tell as the lights on the keyboard flash soon after powering up the computer), I get no picture.  I tried my second 3DFX Voodoo 3 2000 as well as two different ATI 3D Rage IIC AGP cards and neither of them display a picture.  HOWEVER, I put in a Matrox Millennium II PCI graphics card and can get a picture with that.  Something's up with the AGP slot, and I highly doubt the capacitors are the problem because they're all intact.  Not one has bulged or leaked.  Could the slot itself be broken?  Or is the AGP slot's frequency wrong?  This motherboard can use 45(?)MHz or 66MHz on the AGP slot.  What's the proper setting?
But either way, the motherboard works.  Now, I need find a good IDE hard drive and decide which sound card to use as the primary sound card in the computer between my Yamaha YMF744 and OPTi 82C930.  Both have true OPL3 and both have SoundBlaster Pro support, but the YMF744 has on-board XG synth, something the 82C930 doesn't have.  But if I go with the YMF744, I'd need to wire up an SBLink cable.  But before I do so, now that it's been mentioned, I will retrace the connections on the SBLink connector to make sure it's actually connected to the southbridge.
Although this is a test computer for all my ISA and PCI sound cards, so I will be swapping out sound cards regularly in this computer.
												Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
