First post, by srry
- Newbie
New member here, putting together my first retro-style computer, and I've come across something a bit odd (for me). I've never worked with hardware this old before, so much of it is new to me. Turns out my late-90's case actually has TWO separate wire leads both labeled "POWER SW", and both leading directly from the power switch assembly. I'm working with an ATX motherboard, an Abit BX-6 r.2 to be precise. Needless to say, the motherboard only has two power switch pins for a single connector. Is this duplicate connector some sort of holdover from earlier years to ensure AT motherboard compatibility?
I'm guessing I could use either one, since the're marked identically and they both have pairs of red and white wires. I'm not yet at a stage where I can power the system on, so I've not actually tested either.
