Cyberia no mouse problem
First post, by Lopez
Hi guys!
To start with, I used google for 2 hours to solve the problem, and no solution or answer, so please help me.
I love to play this old game from 1994 called Cyberia. I managed to install it, and everything fine: video, sound ect..
The only problem is I can't use mouse in the combat sequence (shooting helicopters and planes sct..). And that's suck because it is nearly impossible to win the game without it.
I tryed:
press the f button during the combat sequence
run the game with cyberia -M
try to lock the mouse in dosbox with ctrl+F10
I have never had problems with using the mouse in any other games before in dosbox.
Please help!
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You probably read the info about the -M parameter and pressing F in the game docs/readme; but apparently overlooked this bit:
Note that the Mouse does not operate in the Gunnery Chair of the Rig.
If you do not have a joystick, use the arror keys to move the gun, the
space bar to fire.
The game does support using the mouse in flight sequences, but a joystick may be preferable.
Reply 2 of 2, by Lopez
Thank you!
Than I try to make it without mouse and hope I can use the mouse next time.
Bye
Lopez
