Reply 440 of 60068, by Tetrium
- l33t++
wrote:Odd looking PSU, dunno yet if a standard will fit without some hacking yet. We'll see how things go
Those Astec PSUs are pretty close to bulletproof... way overbuilt. The low amperage on the 12V line isn't that unusual for older OEM PSUs, and it does have 30A available on 5V, so it'd be a prime candidate for a badass Athlon system if it turns out either of the existing boards doesn't work.
I assumed as much. There was also an Astec PSU in a dual Slot 1 server I was gifted a couple years ago. Unfortunately that PSU seemed to be dead.
Anyhow, I never even heard of Astec before...somekind of subdivision of Antec??? With the Astec standing for server???
wrote:@Tetrium
That's a sweet haul! You have to keep one at least and max it out.. V2 SLI or V5500 PCI would be super in that...and pls post some pics of the final result too!
P.S wish I had the space for that in my house
Yes, will do! I got 2 of those ATX server cases but only took pics of 1 of them as they're identical cases anyway 😀
Problem is, I haven't got a clue if theres any drivers available for this server chipset for 9x. On the HP site it only mentioned drivers for NT4 and Windows 2000 server, I have no idea if 9x will even run on the thing 🙁
