wd wrote:but every time I added something the "size" of the disk decreased faster...weird marketing
As you said they're using compression techniques and for freespace estimation they simply "guess"
that they can compress everything down to 50% size (which is a quite optimistic guess).
I'll stick to .zip or.rar as I rather not want to depend on an "archiver" that I only have 1 use for.
.zip and .rar are simply much easier for me. If stuff on my floppy disk are archived, they will be inside an archive and this will be obvious if I read a disk I put an archive on 5 years ago and had forgotten about.
But DMF I found quite usable for floppies. You format it one extra time (after having done a normal (full!!) format to check the disk for any bad sectors) and you got extra space right there without the extra data being compressed. Handy for files that are in between 1.44 and 1.68 megs in size.
LS-120 took forever to format, but this thread and me coming across my stash of Superdisk stuff kinda resparked my interest in them. And I think the LS-120 disks also look way 'cooler' then the bulky ZIP disks or the more square-ish looking standard floppies.
Too bad I don't have any external LS-120 drives though, the external ZIP 250 USB drive is very neat looking 😁
Also I think 250MB is still a respectable amount of data, especially for a retro rig.
I can't remember if I ever tried USB ZIP drives in Vista/7 though...
