First post, by cpedersen
I am new to the forum, although certainly not new to dos based games - as I cut my teeth on old tandy rs Mod I - and migrated as the years went on.
I am using Megbuild 6, in order to get printing and networking support;
However, the issue is neither of these features.
Megabuild 6 goes completely unresponsive in VGA full screen (640x480 16 colors). Returning to windowed mode makes the system responsive again.
Dosbox .72 does not have these issues. Both full and windowed modes work well.
I have tried changing the machine=vgaonly, and tried various settings of full and window resolution.
I've included a version of the application in the attachment. Run the dp26yu file and then switch to full screen mode and you will see that the application is unresponsive. Switch to windows mode, all is well.
Anyhelp appreciated
Chris
Reply 1 of 6, by leileilol
you have an nvidia card?
Try an output that isn't surface.
Reply 2 of 6, by dosquest
Now, I don't want to step on anyone's toes but I thought we didn't provide support for svn builds?
Reply 3 of 6, by eL_PuSHeR
Related topics merged
Reply 4 of 6, by dosquest
wait, what other related topics? I only see one topic here, the original.
Reply 5 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Do you have anything useful to add or are you just loving the sight of your typing?
When el_Pusher writes he merged related topics he most likely did so. In this case the OP posted the same thing in two new topics while providing some more info in the other one.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 6 of 6, by eL_PuSHeR
Exactly. Thanks Dominus.
