Dos 6 conventional memory tricks
Reply 80 of 298, by DonutKing
I set mine to 9,256
I had problems running somke Lucasarts games like Sam and Max if they were set too low (crashes with a 'stack overflow' error) and also many Apogee games reccomended a minimum setting in their readmes as well 😀
Reply 81 of 298, by schlang
indeed, I had the problem with fate of atlantis 😀
PC#1: K6-III+ 400 | 512MB | Geforce4 | Voodoo1 | SB Live | AWE64 | GUS PNP Pro
PC#2: 486DX2-66 | 64MB | Riva128 | AWE64 | GUS PNP | PAS16
PC#3: 386DX-40 | 32MB | CL-GD5434 | SB Pro | GUS MAX | PAS16
Think you know your games music? Show us: viewtopic.php?f=5&t=37532
Reply 82 of 298, by franpa
I remember going through all this hell, just to get Digital Sound FX in Monster Bash 😀 Took a good portion of 2 or 3 days of serious messing around (Googling) to achieve over I think 590KB EMS RAM though 😳 (Or whatever Monster Bash required)
This was with Windows ME and DOS 8.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 83 of 298, by 7cjbill2
You might be able to find a version of Hyperdrive lurking somewhere on the Internet to replace Smartdrv. Otherwise, score yourself a caching IDE controller and do away with caching programs all together. 😀
Will pay $$$ for:
caching ISA I/O-IDE controller
PM me for my list of trade-ables...
Reply 84 of 298, by Hatta
Does anyone here use the 4DOS command interpreter? I am having trouble getting it to load high. I know I have enough contiguous high memory available because I can load UNIVBE high with no problems, and it's ~18K. 4DOS is only 4K, and is supposed to load all but a few hundred bytes into upper memory. My understanding is that all it takes is 'UMBLoad = Yes' in 4DOS.INI to activate this, but apparently I'm wrong.
I've attached the relevant files in a zip, since apparently the board doesn't accept .bat or .sys attachments. The OS is DOS 6.22 and the 4DOS is 8.00. Does anyone have experience with this?
    4dosumb.zip
    1.64 KiB
    226 downloads
Reply 85 of 298, by soviet conscript
I'm acually having an issue loading UNIVBE into high mem. Its ver 6.7 I think and its the last thing I need put in high mem. i'm trying to load it into region 1 where I have 22kb of free space and UNIVBE is only a tad over 19kb but it will not get out of conventional mem no matter what I try.
Reply 87 of 298, by soviet conscript
Malik wrote:
How's your mem/f and the line that loads the univbe like?
free upper memory
region largest free total free total size
1 22,112 (22k) 27168 (27k)
2 8,336 (8k) 98,320 (96k)
my line for univbe is
LH /L:0;1,19024 /S C:\UNIVBE\UNIVBE.EXE
Reply 88 of 298, by valnar
Try loading it earlier in the autoexec.bat.
Or, if that doesn't work, purposely load something else you have low. eg. If you have a driver that is only 5K, you'd rather leave that low than your 19K driver.
Reply 89 of 298, by Jorpho
What if you just change it to LH C:\UNIVBE\UNIVBE.EXE ?
I presume Memmaker came up with the other stuff, which also suggests you could try running Memmaker again if you've changed other things since the first time you ran it.
Reply 90 of 298, by soviet conscript
memmaker just moves things around, mostly splitting stuff up between region 1 and 2 but I end up with the same amount of conventional mem. when I run mememaker univbe was acually set as "LH C:\UNIVBE\UNIVBE.EXE" but was still being loaded into conventional mem. I added the other stuff in an attempt to load it into region 1 high mem but no luck.
Reply 91 of 298, by Malik
Have you tried loading only UNIVBE high and nothing else from the autoexec.bat? If it can be placed high, then try loading the other TSRs one by one. Sometimes, might need to reshuffle the sequence of loading of the TSRs.
How about even removing other device drivers from config.sys, except himem.sys and emm386.exe with it's normal settings?
And have you tried LH /L:1,19024 (without including region 0), first without /S switch and if not successful, with the /S switch?
And for further experimentation, reserving a slightly higher memory allocation, like
LH /L:1,20000 /S C:\UNIVBE\UNIVBE.EXE ?
Reply 93 of 298, by soviet conscript
I just got back from work so i'm going to try some of your suggestions. I did try removing the region 0 part and oddly enough doing that loads a very tiny fraction of univbe into upper mem. I think 80bytes. or bits or whatever it is its way less then a single kb
Reply 95 of 298, by PhaytalError
Regarding SHSUCDX I couldn't get Sam & Max to run properly with it at all using FreeDOS [no cinemas, no digital speech], had to resort to MSCDEX which unfortunately seems to take alot more conventional memory than SHSUCDX even when loaded high.
Btw this post is done from my DOS Gaming PC. 😁
DOS Gaming System: MS-DOS, AMD K6-III+ 400/ATZ@600Mhz, ASUS P5A v1.04 Motherboard, 32 MB RAM, 17" CRT monitor, Diamond Stealth 64 3000 4mb PCI, SB16 [CT1770], Roland MT-32 & Roland SC-55, 40GB Hard Drive, 3.5" Floppy Drive.
Reply 96 of 298, by Malik
Hmmm...that's strange. I can run the CD using shsucdx. What version are you using? Or maybe it's the combination of freedos and other possible TSRs loaded with it. I'm running ms-dos 6.22.
Reply 97 of 298, by PhaytalError
I think the culprit is FreeDOS itself, dunno if Sam & Max make a special call looking for something within MS-DOS itself or what but in FreeDOS I can't get it to run at all, the cinemas are missing, and no digital sound whatsoever.
So what I ended up doing is, deleted FreeDOS 1.1 and installed MS-DOS 7.1 that I ripped and customized from my Win98SE disc, now the game runs flawless. 😀
