DOSBox keyboard layouts
First post, by blackjudas
After much searching, I cannot find a suitable answer to my question.
When, if at all will DOSBox support different keyboard layouts? Variants on the US keyboard layout such as Dvorak and Colemak. I use colemak and find it extremely aggravating, trying to run any real keyboard based program.
Can anyone shed any light on a workaround or an update on DOSBox development status?
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
load it using keyb.com as mentioned in the documentation ?
Water flows down the stream
Reply 2 of 9, by blackjudas
I admittedly missed the documentation you pointed me to. Though I did google my heart out. The problem with where you pointed me to is simply that I cannot find any support for the colemak layout.
I searched the freedos source for the kl files mentioned. I looked at the list of keyboard layouts on this forum... not there.
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
if nobody has ever bothered to create a colemak layout for freedos, then you are out of luck.
Maybe use a more popular keyboard layout or create it yourself.
Reply 4 of 9, by robertmo
dosbox's keymapper may help
Reply 5 of 9, by blackjudas
Apologies for resurrecting my own dead thread but after posting this here, I went and fiddled some more. FreeDOS and DosEMU etc. I then found that the actual layout was not supported in FreeDOS at all. After contacting the devs, and testing the layout, the layout is now included in the FreeDOS distribution for version 1.1.
My question now is if this layout will now be available in future releases of dosbox because now it's available in FreeDOS?
Reply 6 of 9, by wd
Rank DOSBox Author
DOSBox Author
You can load their .kl files.
Reply 7 of 9, by blackjudas
Yes I know that, I was asking if I should expect the layouts included with DosBOX to be updated upon next release since FreeDOS now has support for Colemak.
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Very unlikely to happen.
Reply 9 of 9, by blackjudas
I assume it'd be futile to ask why not, but thanks for the response.
