First post, by Unregistered
im running win2k and use VDMS for a dos program called Impulse Tracker. i read the threads about IT+VDMS and found no help. was working fine til i installed a new radeon 9600 grafcard. i get the following error:
c:\documentsandsettings\admin\localsettings\temp\~vlp74d5.pif
the NTVDM CPU has encountered an illegal instruction.
CS:0070 IP:426f OP:63 63 65 73 73 Choose close to terminate the application.
i can choose ignore or close. i choose ignore and end up ignoring about 15 identical errors for different files in the same directory. afterwhich the dos box closes. choosing just close closes.
please help me somehow
Reply 1 of 1, by HunterZ
You haven't given enough information. At what exact point does the crash occur, and what are you doing to reproduce it? Also, what exact VDMSound settings are you trying to use with Impulse Tracker?
