Reply 40 of 122, by Davros
- l33t
Ive got terracide
has a 3dfx logo on the box
from the readme
When you first install Terracide, it gives you the option to install DirectX.
This is Microsoft's system which ensures Terracide will run on all machines,
whether unaccelerated, MMX accelerated, or 3D accelerated, and you should
install this version of DirectX (V3.0a) over any earlier versions you have on
your machine. If you install another game or application, and Terracide then
fails to load correctly or becomes unstable, this could be because an earlier
version of DirectX has been installed, either with or without your permission.
Please reinstall the version of DirectX on the Terracide CD and try again.
For the MMX version of Terracide, it is important to remember to install the
MMX option when installing DirectX. NB - due to an unfortunate bug in DirectX,
it appears that you can install the MMX option on DirectX3.0a by _not_ ticking
the MMX option when it becomes available to you.
ps: despite the 3dfx logo on the terracide box i beleive it supports the card via d3d not glide
there are drivers on the cd and the voodoo drivers appear to be d3d only
from the 3dfx drivers readme :
Included Files
DD3DFX.DRV - Direct Draw Driver
DD3DFX16.DLL - DirectDraw 16 Bit DLL
DD3DFX32.DLL - DirectDraw 32 Bit DLL
FXMEMMAP.VXD - Voodoo VXD for Mapping Memory
MSVCRT.DLL - Microsoft Redistributable File
VOODOO.INF - INF File for installing Drivers
README.TXT - This File
other drivers on the cd :
Directory of Z:\DRIVERS
30/04/1999 16:10 <DIR> .
30/04/1999 16:10 <DIR> ..
30/04/1999 16:10 <DIR> ATIRAGE
30/04/1999 16:10 <DIR> MYSTIQUE
30/04/1999 16:10 <DIR> PERMEDIA
30/04/1999 16:10 <DIR> POWERVR
30/04/1999 16:10 <DIR> VIRGE
30/04/1999 16:10 <DIR> VOODOO
ps: are you sure pod gold supports s3d i only remember glide and d3d
