Dark Forces No CD Error
First post, by The_GMan
Im getting a problem with trying to play Dark Forces without a CD. I've followed the instuctions located on your Wiki:
http://www.dosbox.com/wiki/GAMES:Star_Wars:_Dark_Forces
When I go to run the game I get the following error message:
ERROR: Unable to find or read file 'HelNum.fnt'. See manual about making a Boot Disk.
Any help would be appreciated.
Reply 1 of 8, by bloodbat
Did you edit drive.cd?
Reply 2 of 8, by The_GMan
Yep, done that and I still get the error message.
Reply 3 of 8, by bloodbat
Just to make sure, the game *does* work if you play it the normal way? (With a mounted CD and such?).
CD.ID is in the right folder too, right?
Perhaps the game expects to find..say c:\dark\ instead of c:\ the way you installed it...
Fun fact: if you edit drive.cd incorrectly, the game asks you where the CD-ROM...diskette is located 😜
Reply 4 of 8, by jarreboum
I'm having this problem too with the Steam version of Dark Forces. Well, the Steam version works perfectly fine, but when I try to run it with my local version of Dosbox instead of theirs, I'm stuck with the no-cd error.
I have been able to pinpoint the problem to my version of dosbox: I have installed 0.74, while Steam provides 0.73. After having installed 0.73 myself, I was able to succesfully run DARK.EXE. I juggled a bit with the various dosbox.conf files but it didn't change anything.
All this using Windows 7. I also tried Ubuntu 12.04 with 0.74, where I initially encountered the problem. (I tried bypassing it by duplicating steam/dark and mounting one as a cd-rom but the game then complained about missing HelNum.fnt, a file nowhere to be found. But it's probably because the Steam version doesn't have any of the CD files.)
So there seem to be a regression between 0.73 and 0.74 regarding this game. I haven't tried the nightlies.
Reply 5 of 8, by bloodbat
There's no regression, only a misconfiguration on your part, most likely a wrong mount.
How do I know? Below is a screenshot I just took with official, stable, DosBox 0.74 using Steam Dark Forces.
Steam Dark Forces needs the game folder itself to be mounted as C.
Reply 6 of 8, by DosFreak
Works fine in DOSBOX SVN with a image of the original CD. (Didn't test 0.74 although I'm sure I did test it years ago).
Yet another reason why thee services should provide original media.
Make your games work offline
Reply 7 of 8, by bloodbat
Despite me agreeing that they should provide original media, the game works just fine, this is a user error.
Reply 8 of 8, by jarreboum
That's the thing. I tried again today and now everything works. I have no idea what I botched though, I thought I was quite thorough. Oh well.
the game folder doesn't need to be root, as long as CD.ID itself is at the root.
