First post, by eL_PuSHeR
Hello. I have been able to resurrect an old PC someone gave me that was laying around. It is an AMD K6-2 350 with 32MB of PC-100 RAM. It had W98 installed. I reformatted it and installed just ms-dos 6.22
I have tried several games from floppies and none of them was able to output anything than PC Speaker. According to Google CT5803 is SB PCI 128. It seems it may require additional software to run under ms-dos. Or is it AdLib or SB compatible?
Reply 1 of 5, by Jorpho
If it's an SB PCI (and why wouldn't it be?) you'll need SBINIT.COM, I think. Creative probably has the download on their website somewhere.
It works quite nicely, but the driver requires an expanded memory manager, so you'll run into compatibility problems with a vanishingly small number of games for which alternatives are readily available.
Reply 2 of 5, by eL_PuSHeR
Thank you very much for your reply. Nowadays I prefer DOSBox for that kind of task.
Reply 3 of 5, by Ace
One of the worst sound cards I've ever used under DOS. Don't bother with it as yes, it is SoundBlaster and AdLib compatible, but there is no FM Synthesis at all on the sound card. It simulates FM Synthesis much like the older Ensoniq Soundscape and the Ensoniq AudioPCI, which the SoundBlaster PCI128 is based off of, by remapping the FM instructions to the wavetable and results in awful sound. Use a Yamaha YMF7xx sound card if you want a good PCI sound card.
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
Reply 4 of 5, by Robin4
SB PCI 128 is mostly used in a windows 95 /98 environment. So i do not know if there are dos drivers in dos environment.
Reply 5 of 5, by leileilol
There are dos drivers, not to say it's a good card though. Funny if you play games with OPL sound effects 😜
Debian's fucked
