First post, by jcdutton
I am thinking of used some of the source code from the DOSBOX application for my project called revenge. It will be done research into reverse engineering and decompiling.
I will only be taking some .c files from the project and using them only as a template.
Are the authors of this DOSBOX project happy with this sort of use of their source code? I don't want to upset anyone.
