First post, by ik8ozv
Hi Guays,
my name is Enzo from Italy.
Hope posting in the right place.
I have a problem which i hope somebody can help me.
I was using Windows XP till last week and now have bought a new PC that has Windows 7 at 64 Bit O.S.
When i used Windows XP i was using a program that remind me all my To Do during the year like appointments payments exipres ecc.
This progrma worked perfectly and it worked i the automated esecution folder so it loads sho me if there are any appointments and the close.
Unfortunately now it does'nt work on my new PC.
i have made a google searche and found this program DOSBOX that i have tried it and i see that it works greatly.
Now what i want to do is the execute the program in automatic as i done
in the Windows XP but i do not know how to do it.
Anybody can tell me if it is possible and can post me an step by step procedure?
Sure in an help i send my regards to the Forum.
Any help will be really appreciated.
Enzo
Reply 1 of 9, by SKARDAVNELNATE
It sounds like you want the program to start when you turn on the computer. You can do this by placing a shortcut in the Startup folder of the Start menu. The DOSBox readme describes the Command Line Parameters you can use for that. Alternately you can use a front end to make the shortcut for you.
Reply 2 of 9, by ik8ozv
Yes you are correct.
Please can you be so kind to explain me how to do it?
Thanks once more
Enzo
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
yeah, Read the documentation.
Good luck.
Water flows down the stream
Reply 4 of 9, by ik8ozv
I have found the way but i have still one problem.
I have done as to run the program as i load windows but if i need to use just the DOSBOX to run another program, i nee to re edit the configuration file.
Is the a possibilty to use it in both the way?
Thanks
Enzo
Reply 5 of 9, by SKARDAVNELNATE
You can use separate conf files specified in the command line of the shortcut you created.
Reply 6 of 9, by ik8ozv
Please can you explain better for me?
Thanks
Reply 7 of 9, by eL_PuSHeR
Read the DOSBox documentation. The information you seek must be somewhere well hidden.
Reply 8 of 9, by ik8ozv
Please anybody can help me?
i cannot find it.
Thanks
