First post, by theelf
Hi!
I have a AWE64 ISA, and i´m crazy about the different volume levels the card have
The card is working ok, and the mixer settings are all to max
But i have VERY different volumes, i think maybe is the kind of SB type?¿ for example
I think that every game that use adlib or SB original, the volume is insane LOW in FM and Midi
Some games that use SBpro, the midi is LOW but FM is more normal, maybe same happen with SB16...
If i select AWE32 as music, then every is normal
I don´t know what to do, because i try everything... some advice?
Reply 2 of 2, by Davros
are the levels set the same with mixerset ?
