First post, by spektroman
Hello everyone! This is my first post on these forums, so I hope it's the right place to ask for help.
I've recently discovered DosBox and so I've been digging up my old games to play on my brand new MacBook Pro. I'm running into a bit of a snag trying to get Warcraft 2 to work. I actually have the Battle Chest (it's a 3-cd Box with WC1, WC2 and the WC2 expansion).
Well the problem I'm running into is, those games were also made to run on Mac OS "classic" (meaning up to system 9. They won't run on OSX). Because of this, when I put the CD in the drive, it shows me the mac install files.
Since it only shows me the mac files, when I mount the CD drive on DosBox, I can't access the PC files (namely the install.exe I need to run in order to install it).
Is there any way to make DosBox able to read the CD correctly so I can install the game? Just as a clarification, the following command is what I've been using to mount the drive:
mount D "/volumes/Warcraft II CD" -t cdrom switch
The only labels that appear under /volumes on OSX are "Warcraft II CD" and "Warcraft 2 Game Music". I know for a fact that under windows the label (volume name) that displays the PC files is named "WAR2_122" however I don't know how to make DosBox read that particular 'partition' of the CD and I'm stuck seeing only the mac files which does me no good.
So, any suggestions are greatly appreciated. Hopefully my post is clear enough, but I can provide more details as needed.
Thanks in advance!
