First post, by asteff54
Running DOSBox .74 on Windows 7 HP Laptop
Trying to install and run NBA Live 95
I have the original disk in my e: drive
I can only get so far until I receive an error stating that my hard disk is full and I need to delete some file to install the game
Here is what I have so far:
Z:\>mount d e:\ -t cdrom
MSCDEX installed
Drive D is mounted as CDRom e:\
Z:\>d:
d:\>install
DOS/4GW Professional Protected Mode Run-time Version 1.97
Copyright (c) Rational Systems, Inc. 1990-1994
Your hard disk is full.
You need to delete some files before you can install the game.
D:\NBA95>
What do I do now????
(My d drive is my recovery on my laptop)
Reply 1 of 2, by SKARDAVNELNATE
You didn't mount your D drive in the commands you posted. It says "Your hard disk is full" because you only mounted the CD-ROM and the program can't write to it.
