First post, by turbolad
Hi I have 2 simple ideas:
1)
If DOSBox could automatically match the keyboard layout according to the system locale, users would not need to manually edit the .conf file to do this. For instance, if a user has a UK keyboard and they use Windows, Ubuntu or any supported OS with the UK system locale, DOSBox could automatically select the UK keyboard layout. If the user changes the locale, DOSBox could adapt the keyboard layout accordingly the next time DOSBox is started.
2) When the user opens DOSBox they see a blue box with basic information about DOSBox, such as how to adjust the CPU speed etc. Since fullscreen is used a lot in gaming, consider adding this line of info at the bottom of that blue box:
Hold Alt and press Enter to toggle between fullscreen and windowed size at any time.
