First post, by retro games 100
- l33t
After testing a PC, I flick the mains power supply switch on the wall to off. Is it then necessary to remove the mains power supply plug from the socket on the wall, before moving the mobo's cmos settings jumper to the "clear cmos" position? Or is it OK to leave the mains power supply plug inserted in to the wall socket?
I've read something about "power cycles" and PSUs. I vaguely recall that if you remove the mains power supply plug from the wall socket, it does something to the PSU's "state", but I can't remember exactly what.
Also, what is the length of time that the mobo's cmos settings jumper needs to be kept in the "clear cmos" position? Does having the plug removed from the wall socket make any difference to this required time? Thanks a lot for any information.
