First post, by Robin4
Today i received my midiman mpu-401 device..
The floppys warent original.. I get an 1.44 MB HD floppy with software on and tested it and works.. So fast as i could, copy it to my harddisk, before the floppy could get corrupted..
Second floppy is an old blue DS/DD 720KN sony one.. But that one seemed to be a very bad floppy its making weird noises and its hard to read by the floppy drive. I can see the software on it, but one file couldnt be saved when i tried to recover the floppy..
Iam missing this floppy now:
401TEST.EXE ---- 12998
INSTALL.EXE ---- 21844
MM401.EXE ----- 275419
README ---- 6720
README.EXE ---- 3755
SEQ.BAT ------- 29
SYNC.BAT ------ 33
SYSEX.BAT------ 24
VIEW.BAT------- 32
DRIVER.ASM----- 23103
TEST.EXE------- 15232
TEST.C -------- 6667
DRIVER.H------- 4673
DRIVER_S.OBJ--- 1862
DRIVER_M.OBJ--- 1876
DRIVER_C.OBJ--- 1862
DRIVER_L.OBJ--- 1876
SIMPSEQ.EXE --- 94352
TEST.REC ------ 3072
SYNCMAN.EXE---- 72306
VIEWER.EXE----- 55928
D50.LIB-------- 512
FB01CONF.LIB--- 512
FB01VOIC.LIB--- 512
MEP4.LIB------- 512
MT32PTTM.LIB--- 512
MT32RHTH.LIB--- 512
MT32SYS.LIB---- 512
MT32TBTM.LIB--- 512
PROTEUS.LIB---- 512
PROXR.LIB------ 34432
PRO_PROG.LIB--- 512
PRO_TUNE.LIB--- 512
PRO_USER.LIB--- 512
R8.LIB----------512
SYNCOFST.LIB----512
SYNCPLUS.LIB----512
SYNCSTOP.LIB----512
SYNCUSER.LIB----512
I have wrote the file name and size name on notepad, because its easier to regonize which floppy was very bad..
I could almoste recover eventhing accept: MM401.EXE..
So i want to ask the members over here.. Is there anyone that could me give me a copy of this disk?? Because its very hard to find on the internet.
Reply 1 of 16, by Mau1wurf1977
Let me have a look and see if the disk works.
Note however, that you don't require ANY software for driving a MT-32 under DOS.
My YouTube channel
Reply 2 of 16, by SquallStrife
Those MIDI interfaces (Midiman and Roland MPU) are truly Plug 'n' Play.
Just plug it in, and start playing games!
Reply 3 of 16, by Mau1wurf1977
Well I tried the floppy and it can't be read 😒
My YouTube channel
Reply 4 of 16, by Robin4
Ok, it could be plug and play, but i want to full software package of it..
I have also send the seller on ebay a message, i hope they could send me the working one.. If i have it, you can get it from me too.. But let me know if you find something..
Reply 5 of 16, by Robin4
I think i have fixed it.. MM401.EXE wasnt that important file, because it was an extractor file with files that allready bin extracted in that directory...
Then i tested it and seemed working fine.. So if you dont overwrite the other files then its working great..
http://www.megaupload.com/?d=RGQNQRVB
It justs fitts on a 720KB floppy disk.
And maybe the seller send me the new software..
Reply 7 of 16, by Robin4
Iam waiting on a fault less one from the seller.. If i receive it through my e-mail..
I will reupload those one two..
Bad copy pro said that 7.3 procent of the file mm401.exe was bad.. So i cant secure if it would work for 100%..
Here i have a copy of the ROM from the MIDIMAN MM-401 interface card:
http://www.megaupload.com/?d=PMDA4LHL
Its version 1.15 copyrighted at 1991.. So if you want to renew your ROM or fix a dead one.. You could use this one..
Here i post every ROM that i have ripped from the ROM with a programmer:
http://www.vintage-computer.com/vcforum/showt … s-upload-thread
Every rom goes to this site:
http://www.minuszerodegrees.net/rom/rom.htm
Reply 8 of 16, by Robin4
SquallStrife wrote:
I've uploaded this file to the Driver Library. Thanks muchly! 😀
PLEASE RENAME IT IN YOUR DRIVER LIBARY..
MIDIMAN MM401 Driver Disk
Its a MIDIMAN MM401 TEST / DRIVER DISK
So you can see if the devices would work as seposed to do.
Reply 9 of 16, by SquallStrife
No worries.
If you see any other errors, you can actually fix them yourself. The edit function is open to anybody, it's just protected by a CAPTCHA that you have to enter.
Reply 12 of 16, by gerwin
I also have this card, I do not seem to have any software for it, I do have a PDF manual. It is attached.
    MM401-jumpers.pdf
    19.44 KiB
    173 downloads
    Jumpers PDF
    MM401-Manual.pdf
    67.57 KiB
    171 downloads
    Manual PDF
Reply 13 of 16, by megatron-uk
I have the same card - never needed any software: it 'just works', anything that needed the device type/driver specifying worked with a standard MPU401 driver or setting.
https://www.target-earth.net
Reply 14 of 16, by Robin4
Its nice if everything is included, some people use it some dont.. But better have more tools / software then none..
