First post, by Glitchologteam
hello there, in a lot of old pc games and software, I had this application, beavis and butt-head, which is a screen saver and clips compilation. However, when I click on the exe to run the program after it is installed, it freeze an no action can be taken except closing dosbox.
I beleive the problem may be the fact that I do not have Quick Time 1.1.1 that the readme talk.
Do you think quicktime is the problem? If yes, where can I find that old version to run on win 3.11?
THANKS ALOT
Reply 1 of 1, by Glitchologteam
Problem Fixed: I didn't thought that the CD didn't come With Quicktime. Installed it and the program work fine
