First post, by Bryan H
- Newbie
Hi
Have read the readme, but no answer.
I run "Texture" sequencer within Dosbox, and soundcard is RME Fireface 800. (win7 Ultimate 64bit)
The preferred driver for FF800 is "Fireface 800 MIDI (GSIF low latency)", however when I run "mixer /listmidi" in Dosbox all that appears is:-
0   "Microsoft GS Wavetable Synth"
1   "Fireface 800 midi"
No combination of the above works in the config file, and while I can get "Texture" to work through "LOOPmidi", etc the "Fireface 800 MIDI (GSIF low latency)" should be used as there is a latency difference.
How do I get "Fireface 800 MIDI (GSIF low latency)" added to the list that shows up in "mixer /listmidi"?
Any comment appreciated
cheers
Bryan H
