First post, by boredatwork
I have an old .exe program that does read/writes to two files. One is the configuration file and one is a "data" file, basically they are just both ASCII flat files. For some unknown reason, the program will not list the files in the open portion of the program, but I can type in the name and it will open one of them. It will not open the "data" file that goes with it.
The DOSBox shell states this:
SHELL:Redirect output to c:dirfile
The writes to that file work, but nothing else does. All files are readable and writeable through edit, so I'm not sure if I missed some sort of Idiot switch for file usage.
Any help is greatly appreciated.
