memory question
First post, by ncmark
hey guys....
I was looking at this site:
http://www.asus.com/999/html/events/mb/socket … 00/overview.htm
The *manual* says the board supports up to 3-gigs of RAM, and since there are only three slots, so you would have use 1-gig modules.
And yet they only list 256 and 512-mb parts.
Furthermore, it looks like they're saying some of the modules have to be installed in pairs? Is this true? I am afraid I am not that familiar with DDR RAM...
Reply 1 of 5, by Zup
The list is a Qualified Vendor List, e.g.: a list of parts that have been tested and proved to work. You may try any unlisted memory module, and it may work; Asus only guarantee that the listed modules work OK.
The pair of modules is a mistery to me. Some boards need a minimum memory size, so if it needs 256 Mb minimum, it may work with two 128 Mb modules; but in the list seems that some 512 Mb modules must be installed in pairs. It seems related to memory construction, but I wouldn't know if a given memory module would work in the motherboard alone.
I'm selling some stuff!
Reply 2 of 5, by maddmaxstar
A7V600. I've worked with that board before. Should work fine with single 256mb modules. I do believe that board had some issues with DDR400 modules though, that compatibility list is likely a list of DDR400 modules certified to work. Clock it to 333MHz and you should be fine to use anything.
The fault of a lousy implementation of a DDR400 memory controller by VIA on AMD chipsets, plagued many boards of the day.
= Phenom II X6 1090T(HD4850) =
= K7-550(V3-3000) =
= K6-2+ 500(V3-2000) =
= Pentium 75 Gold(Voodoo1) =
= Am486DX4-120(3DXpression+) =
= TI486DLC-40(T8900D) =
= i386sx-16+i387(T8900D) =
Reply 3 of 5, by Tetrium
Maybe this is why my A7V600 didn't like 400Mhz FSB at all. Cheers for pointing this out.
Otoh, I have a Socket A board with KT600 which has been running 2 1gig DIMMs quite happily for a number of years now. It's a Gigabyte board that came with a Fujitsu Siemens computer.
I suppose VIA got it right with their KT880 chipset?
My retro rigs (old topic)
Report spammers here!
Reply 4 of 5, by ncmark
Well I just got one of those boards off Ebay - that is going to be my next build. Probably as a better platform for Linux than the p3-1000 I am using 😀
Reply 5 of 5, by maddmaxstar
I think there was an issue with FSB vs RAM speed in certain cases, but that was probably more an issue with KT400. I believe KT600 on the A7V600 was a bit finicky, 2 of the 3 slots could only be used if using DDR400, add a 3rd and it all knocks down to 333, and was sensitive to RAM brand. Otherwise A7V600 is a solid board.
KT400 on the A7V8X was even worse I think, it was either 1x 400, 2x 333 or 3x 266 I think. It's been a while since I researched all this, just going by what I can recall from 03-05.
As for KT880, I don't think I ever used any of those boards, I'd moved to K8 by that point when they came out. Spec wise they look like an Nforce killer.
= K7-550(V3-3000) =
