First post, by BigBodZod
OK, so I have an older 4-port Trendnet, PS2 + Analog KVM stichbox.
It has served me well but I am noticing some bleed-over from one of the ports into another.
It appears to be just one way so it could be the port on my second machine is what is failing and not the switchbox as a whole.
I am also contemplating getting a newer 24 ~ 26 inch HDMI display so maybe a KVM switchbox supporting HDMI or even a monitor that has a built-in swtichbox, if there is such a thing.
What say you all ?!?
No matter where you go, there you are...
Reply 1 of 2, by TheMAN
there's monitors that support multiple HDMI inputs now I think, so that eliminates that video problem... that means you could still use older style KVM switches
Reply 2 of 2, by BigBodZod
Yeah, I guess I will have to start looking around then, maybe a trip down to Fry's to look at some more displays.
