First post, by MasterChief
My Red Storm Rising is on a 3 1/2 floppy.
I loaded DOSBox .074 and made a dosgames folder on my c drive. I did the modification that when DOSBox is selected that the c:\dosgames is auto mounted. I then mount the "A" drive and select install. Red Storm Rising is loaded into c:\dosgames. I have tried different cpu speeds from 50 to 125 cycles. This is the results of Dir of c:\dosgames:
. <Dir>
. <Dir>
RSR <Dir>
REDSTORM BAT 52
1 file(s) 52 Bytes
3 Dir(s) 262,111,744 Bytes Free
At c:\ I type in REDSTORM
I get on the screen:
C:\>redstorm
then C:\>echo off That's it. Nothing happens. Any help?
MasterChief
