AnDosbox - need help
First post, by El_Matador
Hi all i have problem in my Andosbox in Android 2.3.5 in Samsung Galaxy S II
(sorry for my bad english )
So i have this program but i'm going to up cycles in dosbox.conf , i have windows 98 in this program but this small slowly , i run the games (Tomb Raider II) (GTA 1) but this have 7-10FPS , can i up the speed? (i write 17500 cycles in dosbox conf , it'd good?) I need help 😀
Reply 2 of 27, by El_Matador
But , i write 30000 cycles in computer , ok it's good , but in my phone windows and games is slowly ..... still.
Reply 3 of 27, by El_Matador
I need this games and windows in my phone , why is slowly ?
Reply 4 of 27, by dada
You will never be able to play those games on your phone. Sorry, but there's nothing you can do.
At most you might be able to run some old EGA era games at full speed.
Reply 5 of 27, by El_Matador
🙁:( But this phone is very fast , why in my second computer (Intel Pentium III 750mhz) Dosbox is fast? my phone (1.2Ghz) is slowly?
You can not write any acceleration?
Reply 7 of 27, by El_Matador
So what? I don't understand this , in very slow computer game's and windows run good , but in faster PHONE it's no fast 🙁 Whyyyyy?
Reply 8 of 27, by digistorm
Forget it. DOSBox is fast on any Intel or AMD based system due to the fact that the emulated hardware closely resembles the real hardware. Both real and virtual cpu speak the same language.
With mobile phones and other systems (PowerPC for example) the cpu speaks a completely different language, so there are less "tricks" available to speed things up. Apple did a good job in 2006 with their PowerPC to Intel recompilation library but it may not be applicable to what DOSBox is doing.
Reply 9 of 27, by El_Matador
Is there still a program that will do the trick fairly quickly wyemulować windows 98 on my phone?
Reply 11 of 27, by dada
El_Matador wrote:
🙁:( But
No buts.
edit:
Dominus wrote:
Yes a remote connection program (vnc) that connects and steers a real windows 98 machine.
I bet he's really gonna pursue this option and then come back with more questions...
Reply 12 of 27, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
But then we can say it has nothing to do with dosbox.
@matador: don't go searching for a vnc dos program to run inside andosbox. Look for a native android app.
Further andosbox questions direct at the andosbox author. He sold you this thing so he should support it 😉
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 13 of 27, by El_Matador
Ok , thanks for all responses . 😐
Reply 14 of 27, by yahma
Yeah, try DosBox Turbo. Its significantly faster than andosbox or adosbox in my experience. I play lots of XCom, and its the fastest of all three DOSBOXEN.
Reply 15 of 27, by Qbix
Rank DOSBox Author
DOSBox Author
Why don't those pages have a nice link for the sourcecode by default...
Water flows down the stream
Reply 17 of 27, by mr_bigmouth_502
what I don't get is, why are so many people desperate to run DosBox or Windows on their smartphones? 🤣
Reply 18 of 27, by sliderider
Seriously. Running DOS games was bad enough in the actual DOS era on a 14" screen, it must totally suck on a 4" one. Using a thumb board is not the same as using a genuine clickety-clack keyboard, either.
Reply 19 of 27, by Great Hierophant
Is it inconceivable that someone may want to run DOSBox on a tablet, virtually all of which outside the iPad run Android? The ASUS Transformer series, for example, have a custom keyboard & touchpad dock that, when connected, make the device indistinguishable visibly from many of that company's notebooks. My Samsung Galaxy Epic 4g has a slideout physical keyboard with a number row and cursor keys. It could play a DOS game.
